Has anyone used the QSA module on Nexus 9k switches?
graham.a.clark
I'm a bit of a newbie so apologies if I'm in the wrong forum... Does anyone have experience of using the QSA module on the Nexus 9K series?
I have a Nexus 9236C switch and can't get the QSA module to work, I've tried two of them back-to-back using known good SFP+s and fibres but just can't get a link... I've set the port speed to 10G, any other configs I should be looking at?
Graham
Reza Sharifi
What is the part number on the QSA module?
Also, after you insert the module, what is the output of "sh interface ex/x transceiver"?
