Having some problem of import used switch to Hong Kong
cmo1
Hi, I am having trouble of importing 3 used 1921/K9 switch to build up a lab for CCNA exam, shortly after the switches arrived, the Custom and Excise Department of Hong Kong told me I may infringe the strategic commodity regulation, and request me to fill in the form below to help them to investigate the case.
https://www.cisco.com/c/en/us/products/collateral/routers/1900-series-integrated-services-routers-isr/data_sheet_c78-598389.html
https://www.stc.tid.gov.hk/english/download/files/SC037_2015.pdf
It is not too hard to find used 1921/K9 switch in Hong Kong, but I find a complete solution on Amazon which save me lots of time to get enough equipment to build up a lab, so I decided to bought from oversea instead of local. It is legal to buy used Cisco router like 1921/K9 locally in Hong Kong so I didn't aware of I have to get permit to import it.
Is there anyone work in Cisco can help me to fill in the Form of the above link? Thank you for your attention!
CHEUNG
0 Replies 0
