Having trouble manufacturing a routing loop
ivaarsen1
Greetings!
I'm  practicing some routing techniques related to the Implementing Cisco IP  Routing class and exam.  I'm trying to manufacture a routing loop in  order to correct it with route maps and prefix lists, etc.  I can't seem  to get the routing loop to appear the way I thought it would, and I  would like a hand.
Please consider the topology attached to this post.
The  lab is intended to feature mutual redistribution at two points,  creating a routing loop.  When I redistribute EIGRP into OSPF at R1, for  example, R2 gets the routes expected in it's routing table.  R2's next  hop is R1 to reach the 192.168.253/254.0 networks (this is expected for  now).  When I try to redistribute EIGRP into OSPF at R2 there seems to  be no effect.  R1 maintains its routing table - it's as if the  redistribution commands at R2 never happened.  If I redistribute in the  opposite order (R2 before R1) I have the opposite scenario.
Can  someone please tell me what I'm doing wrong?  I have the lab sitting in  front of me, so I'll be happy to provide any other details required.
Thanks for your time.
Eric
One of the redistribution rules is that only routes from the routing table are considered for redistribution, i.e. only the best routes. In this way R1 learns the routes to 192.168.253 & 254 from R2. Because they are redistributed routes, they are flagged as External type 2 which is the default value.
When R1 subsequently considers the routes to redistribute, for 192.168.253 & 254 it only has the OSPF routes because those are currently in the routing table.
Another default behavior for OSPF is to only redistribute Internal routes.
Because the routes to 192.168.253 & 254 are of the type E2, they are not considered for redistribution.
The EIGRP routes are overruled by OSPF because of their lower AD so they cannot be used. (not in table)
You will get different results when you change the redistribute as follows:
redistribute ospf 1 metric 1 1 255 1 300 match external 2
http://www.cisco.com/en/US/partner/docs/ios/12_2t/ip_route/command/reference/p2ftind2.html#wp1041381
regards,
Leo
lgijssel
Level 9
Level 9
This is a classic problem related to administrative distance.
After redistibuting on R1, R2 learns a route via OSPF.
R2 is however also having a route via EIGRP and this one is preferred because of its lower AD 90 vs 110.
We will need routing tables and configs in order to help you out but fiddling this one out for yourself is of course an excellent learning experience. Have fun!
regards,
Leo
Yes, but the .253/.254 are being redistributed into EIGRP.  Distributing EIGRP into OSPF should make the OSPF path look better, am I not correct?
Configs and routing tables are as follows.  Thanks again for your help.
R1:
Building configuration...
Current configuration : 943 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname ro1
ip subnet-zero
no ip domain-lookup
interface FastEthernet0/0
ip address 10.2.7.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0
ip address 192.168.2.1 255.255.255.0
no fair-queue
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
ip address 10.3.7.1 255.255.255.0
router eigrp 5
network 10.3.7.0 0.0.0.255
network 192.168.2.0
no auto-summary
eigrp log-neighbor-changes
router ospf 1
router-id 1.1.1.1
log-adjacency-changes
redistribute eigrp 5 subnets
network 10.2.7.0 0.0.0.255 area 0
ip classless
ip http server
ip pim bidir-enable
alias exec blank copy flash:blank-config.txt start
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login
R1's routing table:
Gateway of last resort is not set
     10.0.0.0/24 is subnetted, 2 subnets
C       10.3.7.0 is directly connected, Serial0/1
C       10.2.7.0 is directly connected, FastEthernet0/0
O E2 192.168.254.0/24 [110/20] via 10.2.7.2, 00:07:54, FastEthernet0/0
D    192.168.1.0/24 [90/2681856] via 192.168.2.2, 00:12:33, Serial0/0
O E2 192.168.253.0/24 [110/20] via 10.2.7.2, 00:07:54, FastEthernet0/0
C    192.168.2.0/24 is directly connected, Serial0/0
R2:
version 12.4
hostname ro2
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
ip cef
no ip domain lookup
no ip dhcp use vrf connected
ip address 10.2.7.2 255.255.255.0
duplex auto
speed auto
interface FastEthernet2/0
no ip address
shutdown
duplex auto
speed auto
interface Serial2/0
ip address 10.3.7.2 255.255.255.0
interface Serial3/0
interface Serial3/1
no ip address
shutdown
no dce-terminal-timing-enable
interface Serial3/2
no ip address
shutdown
interface Serial3/3
no ip address
shutdown
interface Vlan1
no ip address
router eigrp 5
network 192.168.1.0
no auto-summary
router ospf 1
router-id 2.2.2.2
ip http server
no ip http secure-server
ip classless
control-plane
alias exec frame copy flash:FrameSwitch.txt start
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login
end
R2's routing table:
C       10.3.7.0 is directly connected, Serial2/0
D EX 192.168.254.0/24 [170/2560512256] via 192.168.1.2, 00:10:20, Serial3/0
                      [170/2560512256] via 10.3.7.1, 00:10:20, Serial2/0
C    192.168.1.0/24 is directly connected, Serial3/0
D EX 192.168.253.0/24 [170/2560512256] via 192.168.1.2, 00:10:20, Serial3/0
D    192.168.2.0/24 [90/2681856] via 10.3.7.1, 00:14:54, Serial2/0
R3:
version 12.1
no service single-slot-reload-enable
hostname ro4
ip subnet-zero
no ip domain-lookup
interface Ethernet0
ip address 192.168.253.1 255.255.255.0
no keepalive
interface Ethernet1
ip address 192.168.254.1 255.255.255.0
no keepalive
interface Serial0
ip address 192.168.2.2 255.255.255.0
no fair-queue
clockrate 56000
interface Serial1
ip address 192.168.1.2 255.255.255.0
clockrate 56000
router eigrp 5
redistribute connected metric 1 1 255 1 300
network 192.168.1.0
network 192.168.2.0
no auto-summary
no eigrp log-neighbor-changes
ip classless
ip http server
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
end
R3's routing table:
D       10.3.7.0 [90/2681856] via 192.168.2.1, 00:15:37, Serial0
                 [90/2681856] via 192.168.1.1, 00:15:37, Serial1
D EX    10.2.7.0 [170/2560512256] via 192.168.2.1, 00:15:37, Serial0
                 [170/2560512256] via 192.168.1.1, 00:15:37, Serial1
C    192.168.254.0/24 is directly connected, Ethernet1
C    192.168.1.0/24 is directly connected, Serial1
C    192.168.253.0/24 is directly connected, Ethernet0
regards,
Leo
Yes, thank you for reminding me of things I should know or remember if I'm going to be taking the exam next week.  This is absolutely correct, but my problem was that of metrics.  In the lab I was trying to recreate, I missed the part where the redistributed routes were seeded in such a way that the routing protocols were stepping on each other.  I tweaked my configs and now I've got a real nasty loop going on.  Now the fun starts!
Thanks for your time sir!
