having trouble setting up my 2950
flyntransam
Recently got a 2950 24 port to replace my "dumb hub". Figured it would be nice to practice my cisco on it.
I completely reset everything. atm, all I am doing is trying to set it up to be a dumb hub....
My network tri looks like   MODEM---->router---->Switch----computer
port 1 to router, port 2 is to laptop
I did this to it:
switch>enable
switch#config terminal
switch(config)#interface range fa0/1 - 24
switch(config-if-range)#switchport host
switch(config-if-range)#end
switch#write mem
My current running config:
Current configuration : 2275 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
ip subnet-zero
ip ssh time-out 120
ip ssh authentication-retries 3
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
switchport mode access
spanning-tree portfast
interface FastEthernet0/2
Switch#show vlan
VLAN Name                             Status    Ports
1    default                          active    Fa0/1, Fa0/2, Fa0/3, Fa0/4
                                                Fa0/5, Fa0/6, Fa0/7, Fa0/8
                                                Fa0/9, Fa0/10, Fa0/11, Fa0/12
                                                Fa0/13, Fa0/14, Fa0/15, Fa0/16
                                                Fa0/17, Fa0/18, Fa0/19, Fa0/20
                                                Fa0/21, Fa0/22, Fa0/23, Fa0/24
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        0      0
1003 tr    101003     1500  -      -      -        -    -        0      0
1004 fdnet 101004     1500  -      -      -        ieee -        0      0
1005 trnet 101005     1500  -      -      -        ibm  -        0      0
I have tried setting this thing up the last few days with no luck. I can only console. It never pings when tryin gto setup the vlan. open to any ideas or suggestions. Would like to get it working for http/telnet, but setting that i figured out how to do. Just my switch never talks to my router....
the int Vlan 1 is shutdown, that might be why switch and router cant connect n ping.
int vlan 1
no shut
but as for the switching itself, this shouldnt be an issue!
what's the ip addresses of the PC and the router? do you have good physical connections?
Hope it Helps,
Soroush.
Hope it Helps!
Soroush.
10 Replies 10
smehrnia
Level 7
Level 7
hi brian,
you want to ping your switch from the router? if yes, did u set up an IP address for ur switch?
can you ping ur router from ur computer or thats disconnected too?
HTH,
plz Rate if it helped,
Soroush.
Hope it Helps!
Soroush.
i did not setup an Ip. I have tried to do that before witn no luck. I know how to set it, just it never seems to connect to my router.
at this point, All I want it to do is act like a hub.
you have a Management vlan, by default its Vlan 1. you go to interface vlan 1, set an ip address in ur segment's ip range, and there you go. thats because you have Layer 2 switch. Only one ip address n its for management purposes!
interface vlan 1
ip address x.x.x.x
exit
Hope it Helps,
Soroush.
Hope it Helps!
Soroush.
have u tried erasing to the factory default n see how it goes?
conf t
write erase
and power cycle.
HTH,
Soroush.
Hope it Helps!
Soroush.
pjmonline
You need to setup a management ip on vlan 1
Config t
Int vlan 1
Ip address 192.168.0.2 255.255.255.0
Why do I need to setup the Vlan if I only want to use it as a hub? Isn't the vlan for admin use only??
I did it anyways:
Switch>en
Switch#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Switch(config)#int vlan 1
Switch(config-if)#ip address 192.168.2.2 255.255.255.0
Switch(config-if)#exit
Switch(config)#exit
still have the same issue. computer connected to switch won't connect to the lan.
router does not see switch, switch won't ping the router....
interface Vlan1
no ip route-cache
shutdown
ip http server
line con 0
line vty 5 15
end
Brian
I have completely reset this switch a few times....
int vlan 1
no shut
Hope it Helps,
Soroush.
Hope it Helps!
Soroush.
ok, forgot to do a no shut, did that.
It does work now. To be honest, I think my issue was the switch was still plugged into my old hub, then to the router.
either way it is working now!
now to get the web interface working and I'll be a happy camper!
the hub is a transparent device, so it shouldnt make a difference, unless its damaged.
btw glad its fixed
mark the question as answered, helps others with similar issues find an answer.
CheerZ!
Soroush.
Hope it Helps!
Soroush.
