health Check Using Network Assistant
majdalani
hi,
I usually use Cisco Network Assistant to check and perfom configuration for my 2950 / 2970 switches.
I Need to check my switches healthes, so i went to the monitoring options and i see bandwidth graph, CPU, Memory, Utilization.
Is there any average % for any of these.
For example if the Utilization is shown in the graph to be 35 % is this good or bad ?
Thanks in advance.
jsivulka
Level 5
Level 5
There is no any average % for bandwidth graph, CPU, Memory, Utilization. It will differ by using traffic as well as network utilization.
http://www.cisco.com/en/US/customer/docs/net_mgmt/cisco_network_assistant/version3_0/release/notes/OL8231.html
Thanks for your reply.
But once i click on the above link, i recieve file forbidden page !
