Help configuring ACL's
worldbuilder
Hi all,
I have a 2611 router I have just set up at my house (for learning to get CCNA). It is NOT live on the network yet, though. I want to get some anti-spoofing and regular traffic ACL's in place first before I take it live.
My LAN scheme is 192.168.5.0/24.
I will be setting up DHCP, which I'm comfortable with.
e0/0 is attached to my ISP (Comcast) and will be getting a DHCP address from them.
e0/1 connects to my internal LAN and will be handing out DHCP addresses. It is configured as 192.168.5.73 255.255.255.0.
I have some ACL's in mind that I've developed from reading, but i am wary of my knowledge of ACL's and could use help.
So here we go...
The first one I think I need to write is this (to let my LAN traffic out):
Hercules(config)#access-list 101 deny ip any any
Hercules(config)#access-list 101 permit ip 192.168.5.0 0.0.0.255 any
Hercules(config)#int e0/0
Hercules(config-if)#ip access-group 101 out
Now, in my studies, I THINK this means that ONLY traffic from my LAN ( 192.168.5.0) will be allowed out e0/0, which as stated above connects to the internet. Are my statements right? Wrong? Have I set the interface right, or should that ACL be on e0/1?
Secondly, preventing evil traffic from coming in (as much as possible):
Hercules(config)#access-list 102 deny ip 10.0.0.0 0.255.255.255 any
Hercules(config)#access-list 102 deny ip 127.0.0.0 0.255.255.255 any
Hercules(config)#access-list 102 deny ip 172.16.0.0 0.0.255.255 any
Hercules(config)#access-list 102 deny ip 192.168.0.0 0.0.255.255 any
Hercules(config)#access-list 102 deny ip 224.0.0.0 31.0.255.255 any
Hercules(config)#int e0/1
Hercules(config-if)#ip access-group 102 out
Am I correct in thinking that these are ACL's that will prevent packets spoofed as internal addresses from entering my network through e0/1 (which as stated above connects to my LAN)? Are the commands right, on the right interface, and going the right direction?
And finally, I have a web server (port 80) and a mail server (port 25) running on a linux machine on my LAN. The IP of that machine is 192.168.5.1. Am I correct in thinking that the following two commands will allow access through the 2611 to my server apps?
Hercules(config)#ip nat inside source static tcp 192.168.5.1 80 int e0/1 80
Hercules(config)#ip nat inside source static tcp 192.168.5.1 25 int e0/1 25
... If I've set:
Hercules(config-if)#ip nat outside
and
Hercules(config-if)#ip nat inside
Will any of my ACL's restrict web or mail server access in any way?
I'd greatly appreciate info from you experts!
Many thanks,
Chris
7 Replies 7
Adam Frederick
Level 3
Level 3
You don't need to worry about permitting in to out..
Also keep in mind you have an implicit
"deny any" at the end of your ACL so you do not need this at the beginning, if you do, you're just going to deny EVERYTHING.
You can control your IN to OUT traffic via NAT. If you only setup a pool for the 192.168.5.0/24 subnet then your going to be ensuring only that subnet gets a global address.
Even though you have a static NAT mapping to your mail and web server, you still need an ACL on your outside interface to permit only these 2 ports.
I.e - access-list 150 permit ip any any eq 25
access-list 150 permit ip any any eq 80
Then the implicit "deny any" will kick in and deny everything else. Trust me, ACLs come with time but they are really simple with small networks.
^^ Ok, so delete this entirely? ^^
Ok, so I should write:
Hercules(config)#access-list 150 permit ip any any eq 25
Hercules(config)#access-list 150 permit ip any any eq 80
Hercules(config-if)#ip access-group 101 out (or in)?
It would be "in", right, because I want it to filter inbound packets on the outside interface...
So in total, if I understand you right, my entire ACL's would be...
Don't I also need ONE permit statement in this ACL? What would that be?
Then I'll have an implicit "deny all".
Hercules(config-if)#ip access-group 150 in
Sorry, I am terrible at ACL's...
Many thanks!
Chris
Sureshdank
This access-list which you have implemented on e0/1 i.e. Internal PORT. will itself blockt your internal traffic. Because the access says that deny anything for 192.168.0.0 network.
Secondly the NAT what you have given is not correct. Just go through this link,
http://www.tech-recipes.com/rx/713/cisco_how_to_configure_nat_network_address_translation
As you are saying that you are configured Web Server and MAIL in your local LAN and you get a Public IP through DHCP then it is not possible for you to host these servers outside world, as the public will be keep on chaiging right.
You need to have static ip for that.
Hope that helps.
Pls. rate the post.
Suresh Jain
great info great links
This access-list which you have implemented on e0/1 i.e. Internal PORT. will itself block your internal traffic. Because the access says that deny anything for 192.168.0.0 network.
So what if I added Hercules(config)#access-list 102 permit ip 192.168.5.0 0.0.255.255 any - Since 192.168.5.0 is my LAN scheme. Then it should permit my traffic, right?
So how about:
Hercules(config)#access-list 1 permit 192.168.5.0
Hercules(config)#ip nat inside source list access-list 1 e0/0 overload
Actually, it IS possible. I do it now... But you're right, it's a PITA with DHCP. When my ISP does change my IP address (about twice a year), I have to reroute DNS with my registrar and wait a few days. But I'll need to forward ports through the 2611, so:
should work, right? Or should the interfaces in the above two commands be e0/0, not e0/1 like they are above?
Thanks guys for all your help.
Chris
So after reviewing all the replies from you fine gentlemen, I think I've got it... Remembering that my e0/0 is connected to the internet, e0/1 is connected to the LAN, and that I need to make sure people can still get to me web and mail server at 192.168.5.1, I now have:
^^^^Is this correct for simply NAT'ing and getting all machines on my LAN to the web?^^^^
Hercules(config-if)#ip access-group 150 e0/0 in
^^^^Is this correct for setting up port forwarding to my web & mail server while denying other traffic?^^^^
Hercules(config)#access-list 102 permit ip 192.168.5.0 0.0.0.255 any
^^^^Is this correct for setting an anti-spoofing, DoS-attempt ACL while still allowing my 192.168.5.0 network?^^^^
Are my ACL's applied to the right interfaces?
Are my ACL's and NAT going in the right direction?
I greatly appreciate your help, friends! I apologize for having such a hard time with this. Some of the things said, I understand, some I don't.
If, in fact, this is still wrong, could someone possibly rewrite my ACL's to be correct, explaining the differences? That may help me understand better.
Many continued thanks!
Chris
Guys, is the above correct?
I certainly don't want to be pushy, but I'd like to get going on this.
Thank you very, very much!
Chris
