Help Configuring VLan for Internet Only Traffic
jhiggins2001
I have a Cisco Catalyst 3750 Switch with a 2500 series Wireless Controller. I have multiple vlans, and 3 wireless networks. I have created a new vlan and wireless network, both work just like the other vlans and wireless. The problem is when I try to apply ACLs to limit traffic to internet only neither will work.
Subnets I don’t what access to:
172.16.2.0/23
172.16.4.0/23
172.16.6.0/24
10.10.10.0/24
Subnet to go to Internet:
172.18.20. 0/22
My goals are these:
1. Limit the new subnet to Internet only access
2. Be able to receive DHCP addresses on new subnet
3. DNS is optional as I have external DNS servers in the DHCP options
4. Be able to use wired or wireless on new subnet.
Any help is greatly appreciated.
You have the source and destination flipped for DHCP:
access-list 120 permit udp any host 10.10.10.5 eq bootpc
access-list 120 permit udp any host 10.10.10.5 eq bootps
Also, as the last line of the ACL, you can add the line:
deny ip any any log
This will create a log of traffic that doesn't hit one of the rules. It can be helpful in diagnosing issues with ACLs. You don't need to leave it there permanently. I typically will add it only if/when there are issues with traffic hitting an element in the ACL. You'll need to remove the permit any any to make this work.
5 Replies 5
rfalconer.sffcu
Level 3
Level 3
Write an ACL with a source of 172.18.20.0/22 that does the following in this order:
Permits DHCP to specific DHCP server(s)
Deny IP to the subnets that you want to protect
Permit internet traffic (www,https,dns at a minimum) to anywhere
Apply ACL to the SVI for 172.18.20.0/22
Robert, Thanks for the reply.
OK, I tried doing as you said, but I still can'e get an IP when I have ACL applied. What should my Permit DHCP statement look like? I have:
access-list 120 permit udp host 10.10.10.5 any eq bootpc
access-list 120 permit udp host 10.10.10.5 any eq bootps
Where 10.10.10.5 is my DHCP
Then I have deny statements on the rest of my subnets followed by Permit:
access-list 120 permit ip any any
John
Hi.
ip access-list extended TO-The-Net
deny ip 172.18.20.0 0.0.3.255  172.16.2.0 0.0.1.255
deny ip 172.18.20.0 0.0.3.255  172.16.4.0 0.0.1.255
deny ip 172.18.20.0 0.0.3.255  172.16.6.0 0.0.0.255
deny ip 172.18.20.0 0.0.3.255  172.16.10.0 0.0.0.255
permit ip 172.18.20.0 0.0.3.255 any
This acl , applyed in ingress to the SVI, should meet your needs.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
deny ip any any log
That did the trick. Thanks.
Thanks to Carlo as well.
