Help - DHCP to multiple vlans
agutthon777
I can not get dhcp to work... I am pulling my hair out of my head!!!!!! I can ping from the switch to both vlans...  HELP!!!!!!!
here is my config for the router.....
Router is a 1760
Current configuration : 1379 bytes
version 12.4
hostname intra-vlan
boot-start-marker
boot-end-marker
enable password xxxxxxx
no aaa new-model
resource policy
ip cef
no ip dhcp use vrf connected
ip dhcp pool voip
   network 192.168.2.0 255.255.255.0
   default-router 192.168.2.1
   option 150 ip 192.168.1.103
interface FastEthernet0/0
no ip address
speed 100
full-duplex
interface FastEthernet0/0.1
description management VLAN
encapsulation dot1Q 1 native
ip address 192.168.1.252 255.255.255.0
ip nat inside
no snmp trap link-status
interface FastEthernet0/0.2
description voip VLAN
encapsulation dot1Q 2
ip address 192.168.2.1 255.255.255.0
interface FastEthernet0/0.3
description Data VLAN
encapsulation dot1Q 3
ip address 192.168.3.1 255.255.255.0
ip nat inside
interface Serial0/0
no ip address
shutdown
no fair-queue
ip default-gateway 192.168.1.254
ip route 0.0.0.0 0.0.0.0 192.168.1.254
no ip http server
no ip http secure-server
control-plane
banner motd ^CC ***************** you have reached intra-vlan router **************** ^C
Switch is a 2950
Here is my configuration for my switch
Current configuration : 3892 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname switch
ip subnet-zero
no ip domain-lookup
spanning-tree mode pvst
spanning-tree portfast default
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
description att gateway to internet ip 192.168.1.254
switchport mode access
no ip address
duplex full
speed 100
interface FastEthernet0/2
description VOIP PHONE
switchport access vlan 2
no ip address
duplex full
speed 100
interface FastEthernet0/3
description voip phone 7941
no ip address
duplex full
speed 100
interface FastEthernet0/4
description cisco 1760 router - intra-vlan ip 192.168.1.252
no ip address
duplex full
speed 100
interface FastEthernet0/5
description linksys ata analog phone
no ip address
duplex full
speed 100
interface FastEthernet0/6
no ip address
duplex full
speed 100
interface FastEthernet0/7
description ibm laptop docking station
no ip address
duplex full
speed 100
interface FastEthernet0/8
description cisco 1760 router - vpn gateway
no ip address
duplex full
speed 100
interface FastEthernet0/9
description hp laserjet printer ip 192.168.1.250
no ip address
duplex full
speed 100
interface FastEthernet0/10
no ip address
duplex full
speed 100
interface FastEthernet0/11
no ip address
duplex full
speed 100
interface FastEthernet0/12
description sony blu-ray dvd player
no ip address
duplex full
speed 100
interface FastEthernet0/13
no ip address
duplex full
speed 100
interface FastEthernet0/14
no ip address
duplex full
speed 100
interface FastEthernet0/15
no ip address
duplex full
speed 100
interface FastEthernet0/16
no ip address
duplex full
speed 100
interface FastEthernet0/17
no ip address
duplex full
speed 100
interface FastEthernet0/18
no ip address
duplex full
speed 100
interface FastEthernet0/19
no ip address
duplex full
speed 100
interface FastEthernet0/20
no ip address
duplex full
speed 100
interface FastEthernet0/21
no ip address
duplex full
speed 100
interface FastEthernet0/22
no ip address
duplex full
speed 100
interface FastEthernet0/23
no ip address
duplex full
speed 100
interface FastEthernet0/24
description trunk port for poe switch
switchport mode trunk
no ip address
interface GigabitEthernet0/1
description elastix server ip 192.168.1.103
no ip address
interface GigabitEthernet0/2
no ip address
interface Vlan1
description management vlan 1
ip address 192.168.1.249 255.255.255.0
no ip route-cache
ip http server
banner motd ^CC ************* you have reached the main switch ***************** ^C
Reza Sharifi
You have configured 2 vlans on your switch (vlan 1 and vlan 2). In this case interface fa0/4 need to be a trunk port and not an access port.  You also need a default-gateway on the switch pointing to the manament interface on the router
(192.168.1.252)
From the DHCP can you ping
192.168.1.252
and
192.168.2.1
on the router since you already have a default router, than you don't need this command:
