Help fixing duplicate IP address on Vlan1
Clay Plaga
Level 3
Level 3
I am getting an error on my Cisco 2960G switch that says “ duplicate address 192.168.1.10 on Vlan1, sourced by 08cc.68bc.1304.” The switch is connected to a Cisco 1800 router. This is a test network that I am using to study for my Cisco certification.
I am just beginning to learn switches.
I have included 2 screenshots from the switch.
Can someone assist me with fixing this error. What should I check first?
switch_duplicate_IP.pngswitch_duplicate_IP2.png I
Thank you for your help. Yes, I did fix it. With the commands you gave me, I found the MAC address, and then I traced the MAC to one of my access points. The access point had the wrong IP address. I checked my DHCP on the domain controller, and found that IP address had been issued a lease. I deleted the entry and it cleared the vlan error. Thanks again!
7 Replies 7
chrihussey
Identify the ports that the mac addresses belong. "show mac address-table xxxx.xxxx.xxxx"
Once you find the ports, identify the attached devices and check their IPs.
Also, not sure how involved of a test network you have but if you can post the configs of the 2960G and 1800, it may be easier to help.
Thank you for helping me. What do I enter for the x's?
The MAC address
"show mac address-table address 08cc.68bc.1af0"
I really appreciate you trying to help me, but the show mac address-table is not working for me. I have a cisco 2960g switch. I have included a screenshot. Thank you.show_mac address table.png
There is no hyphen between mac-address:
"sh mac address-table address xxxx.xxxx.xxxx"
If you type:
sh mac ?
it gives you the next options to help you step through the command.
I have a 2960, this is the syntax as posted earlier:
You'll need to do this command for both MACs that are showing up as a duplicate to locate both devices.
