10-02-2012 06:15 AM - edited 03-07-2019 09:13 AM
hi ,
im trying to simulate LAC - LNS using L2TP tunnel
it seesm that the tunnel is not up
the topology is as shown :
plz have a lokk about the config below and why the tunnel is not up ?
LAC#
LAC#sh ip int b
FastEthernet0/0 1.1.1.6 YES manual up up
FastEthernet1/0 10.252.102.49 YES manual up up
FastEthernet2/0 unassigned YES unset administratively down down
FastEthernet3/0 unassigned YES unset administratively down down
Virtual-Access1 unassigned YES unset up up
Virtual-Template1 10.252.102.49 YES TFTP down down
Virtual-Access2 unassigned YES unset down down
LAC#
LAC#
LAC#sh run
LAC#sh running-config
Building configuration...
Current configuration : 1223 bytes
version 12.4
hostname LAC
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
memory-size iomem 5
ip subnet-zero
ip cef
no ip domain lookup
vpdn enable
vpdn search-order domain
vpdn-group 1
request-dialin
protocol l2tp
domain rracuares.com
initiate-to ip 1.1.1.8 priority 1
local name LAC
l2tp tunnel password 0 rracuares
bba-group pppoe global
virtual-template 1
interface FastEthernet0/0
ip address 1.1.1.6 255.255.255.0
duplex auto
speed auto
interface FastEthernet1/0
ip address 10.252.102.49 255.255.255.240
duplex auto
speed auto
pppoe enable group global
interface FastEthernet2/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet3/0
no ip address
shutdown
duplex auto
speed auto
interface Virtual-Template1
ip unnumbered FastEthernet1/0
ppp authentication pap
no ip http server
no ip http secure-server
ip classless
control-plane
line con 0
exec-timeout 0 0
password 123
logging synchronous
login
line aux 0
line vty 0 4
end
LNS#sh int
LNS#sh ip int b
FastEthernet0/0 unassigned YES unset administratively down down
FastEthernet1/0 1.1.1.8 YES manual up up
Virtual-Access1 unassigned YES unset down down
Virtual-Template1 1.1.1.8 YES TFTP down down
LNS#sh run
LNS#sh running-config
Current configuration : 1318 bytes
version 12.4
hostname LNS
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login default local
aaa authentication ppp default local
aaa authorization network default local
aaa session-id common
resource policy
memory-size iomem 5
ip subnet-zero
ip cef
no ip domain lookup
vpdn enable
vpdn-group 1
accept-dialin
protocol l2tp
virtual-template 1
terminate-from hostname LAC
source-ip 1.1.1.8
username rejohn@cuares.com privilege 0 password 0 rejohn
no ip address
shutdown
duplex auto
speed auto
ip address 1.1.1.8 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip mtu 1492
peer default ip address pool PPPoE-POOL
ip local pool PPPoE-POOL 20.20.20.2 20.20.20.254
no ip http server
ip classless
control-plane
line con 0
exec-timeout 0 0
password 123
logging synchronous
line aux 0
line vty 0 4
end
LNS#
10-02-2012 06:39 AM
Hello Ahmed,
L2TPv2 can be used to extend PPP sessions over an L2TPv2 tunnel
You miss the PPPoE client device that should start a PPPoE session to LAC device that is extended/propagated to LNS
Change SW1 in a router and configure it to act as a PPPoE client connected to LAC fas1/0
It would be wise also to remove ip address from LAC fas1/0 it has to act as PPPoE server side only
Hope to help
Giuseppe
10-02-2012 07:21 AM
hi
Giuseppe
thanks for your reply ,
i will configure ppoe client and give u a reply
10-03-2012 12:28 AM
hi
Giuseppe
i wanna ask ,
if i connect an adsl router and configured it to work as pppoe clinet ,will it work??
i mean can i simultea the adsl connectivity and connect common adsl routers like dlink or dlink or cisco .... etc ??
regards
10-03-2012 03:31 AM
hi ,
i connected a router with f0/0 with switch and here is the config of the pppoe router :
the problem is still and no vpdn is up , noe that intrface of LAC F1/0 has no ip address .
PPPOE#sh run
PPPOE#sh running-config
Current configuration : 1004 bytes
version 12.4
hostname PPPOE
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
memory-size iomem 5
ip subnet-zero
ip cef
interface Loopback0
ip address 1.1.1.5 255.255.255.0
no ip address
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface Dialer1
ip address negotiated
encapsulation ppp
dialer pool 1
ppp pap sent-username rejohn@cuares.com password 0 rejohn
ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
control-plane
line con 0
line aux 0
line vty 0 4
end
PPPOE#
10-03-2012 08:39 AM
Hello Ahmed,
you need a PPPoE client config like the one described here. Note you don't need the vpdn configuration on newer devices.
I would expect to see somthing like
interface Ethernet0/1 no ip address pppoe enable >>>>pppoe-client dial-pool-number 1 ! interface Dialer1 ip address negotiated ip nat outside ip mtu 1492 encapsulation ppp no ip mroute-cache dialer pool 1 dialer-group 1 ppp authenticatio...
You may need just to add the pppoe client command to tie the dialer interface to the physical interface
Hope to help
Giuseppe
10-03-2012 11:41 AM
hi
Giuseppe,
thanks for ur reply ,
sorry to say that after adding the command
it didnt succed .
note after adding commands , the ppoe client router has a consloe message freuqently appear :
*Mar 1 05:40:16.110: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to up
*Mar 1 05:40:16.558: %DIALER-6-UNBIND: Interface Vi2 unbound from profile Di1
*Mar 1 05:40:16.566: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to down
*Mar 1 05:40:38.658: %DIALER-6-BIND: Interface Vi2 bound to profile Di1
*Mar 1 05:40:38.666: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to up
*Mar 1 05:40:39.054: %DIALER-6-UNBIND: Interface Vi2 unbound from profile Di1
*Mar 1 05:40:39.062: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to down
*Mar 1 05:41:01.190: %DIALER-6-BIND: Interface Vi2 bound to profile Di1
*Mar 1 05:41:01.198: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to up
*Mar 1 05:41:01.614: %DIALER-6-UNBIND: Interface Vi2 unbound from profile Di1
*Mar 1 05:41:01.622: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to down
*Mar 1 05:41:23.722: %DIALER-6-BIND: Interface Vi2 bound to profile Di1
*Mar 1 05:41:23.730: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to up
*Mar 1 05:41:24.094: %DIALER-6-UNBIND: Interface Vi2 unbound from profile Di1
*Mar 1 05:41:24.102: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to down
*Mar 1 05:41:46.214: %DIALER-6-BIND: Interface Vi2 bound to profile Di1
*Mar 1 05:41:46.222: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to up
*Mar 1 05:41:46.642: %DIALER-6-UNBIND: Interface Vi2 unbound from profile Di1
*Mar 1 05:41:46.650: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to down
*Mar 1 05:42:08.766: %DIALER-6-BIND: Interface Vi2 bound to profile Di1
*Mar 1 05:42:08.774: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to up
*Mar 1 05:42:09.162: %DIALER-6-UNBIND: Interface Vi2 unbound from profile Di1
*Mar 1 05:42:09.170: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to down
*Mar 1 05:42:31.386: %DIALER-6-BIND: Interface Vi2 bound to profile Di1
*Mar 1 05:42:31.394: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to up
*Mar 1 05:42:31.782: %DIALER-6-UNBIND: Interface Vi2 unbound from profile Di1
*Mar 1 05:42:31.790: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to down
*Mar 1 05:42:53.890: %DIALER-6-BIND: Interface Vi2 bound to profile Di1
*Mar 1 05:42:53.898: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to up
*Mar 1 05:42:54.290: %DIALER-6-UNBIND: Interface Vi2 unbound from profile Di1
*Mar 1 05:42:54.298: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to down
*Mar 1 05:43:16.378: %DIALER-6-BIND: Interface Vi2 bound to profile Di1
*Mar 1 05:43:16.386: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to up
*Mar 1 05:43:16.806: %DIALER-6-UNBIND: Interface Vi2 unbound from profile Di1
*Mar 1 05:43:16.814: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to down
again , my topology is :
PPPOE#sh run
Current configuration : 1171 bytes
version 12.4
hostname PPPOE
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
memory-size iomem 5
ip subnet-zero
ip cef
interface Loopback0
no ip address
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface Dialer1
ip mtu 1492
ip nat outside
ip virtual-reassembly
encapsulation ppp
no ip route-cache cef
no ip route-cache
dialer pool 1
dialer-group 1
ip http server
ip classless
control-plane
line con 0
line aux 0
line vty 0 4
end
PPPOE#sh run
version 12.4
hostname PPPOE
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
memory-size iomem 5
ip subnet-zero
ip cef
interface Loopback0
no ip address
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface Dialer1
ip mtu 1492
ip nat outside
encapsulation ppp
no ip route-cache
dialer pool 1
dialer-group 1
ip http server
ip classless
control-plane
line con 0
line aux 0
line vty 0 4
end
version 12.4
hostname LNS
boot-start-marker
boot-end-marker
aaa new-model
resource policy
memory-size iomem 5
ip subnet-zero
ip cef
no ip domain lookup
vpdn enable
vpdn-group 1
accept-dialin
protocol l2tp
virtual-template 1
source-ip 1.1.1.8
no ip address
shutdown
duplex auto
speed auto
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip mtu 1492
no ip http server
ip classless
control-plane
line con 0
exec-timeout 0 0
password 123
logging synchronous
line aux 0
line vty 0 4
end
LNS#
about the console messages on LAC
*Mar 1 12:23:52.428: [74]PPPoE 74: O
C0 21 01 01 00 12 01 04 05 D4 03 04 C0 23 05 06
02 D0 E1 D3
*Mar 1 12:23:52.432: [74]PPPoE 74: State PPP_START Event DYN_BIND
*Mar 1 12:23:52.432: [74]PPPoE 74: data path set to PPP
*Mar 1 12:23:52.528: [74]PPPoE 74: O
C0 21 03 01 00 09 03 05 C2 23 05
*Mar 1 12:23:52.568: [74]PPPoE 74: O
C0 21 03 02 00 09 03 05 C2 23 05
*Mar 1 12:23:52.600: [74]PPPoE 74: O
C0 21 03 03 00 09 03 05 C2 23 05
*Mar 1 12:23:52.624: [74]PPPoE 74: O
C0 21 03 04 00 09 03 05 C2 23 05
*Mar 1 12:23:52.640: [74]PPPoE 74: O
C0 21 03 05 00 09 03 05 C2 23 05
*Mar 1 12:23:52.660: [74]PPPoE 74: O
C0 21 04 06 00 08 03 04 C0 23
*Mar 1 12:23:52.684: [74]PPPoE 74: O
C0 21 04 07 00 08 03 04 C0 23
*Mar 1 12:23:52.704: [74]PPPoE 74: O
C0 21 04 08 00 08 03 04 C0 23
*Mar 1 12:23:52.724: [74]PPPoE 74: O
C0 21 04 09 00 08 03 04 C0 23
*Mar 1 12:23:52.748: [74]PPPoE 74: O
C0 21 04 0A 00 08 03 04 C0 23
*Mar 1 12:23:52.764: [74]PPPoE 74: O
C0 21 04 0B 00 08 03 04 C0 23
*Mar 1 12:23:52.788: [74]PPPoE 74: O
C0 21 04 0C 00 08 03 04 C0 23
*Mar 1 12:23:52.804: [74]PPPoE 74: O
C0 21 04 0D 00 08 03 04 C0 23
*Mar 1 12:23:52.824: [74]PPPoE 74: O
C0 21 04 0E 00 08 03 04 C0 23
*Mar 1 12:23:52.844: [74]PPPoE 74: O
C0 21 04 0F 00 08 03 04 C0 23
*Mar 1 12:23:52.864: PPPoE 74: I PADT R:cc04.27d8.0000 L:cc00.27d8.0010 Fa1/0
CC 00 27 D8 00 10 CC 04 27 D8 00 00 88 63 11 A7
00 4A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ...
*Mar 1 12:23:52.868: [74]PPPoE 74: O
C0 21 05 01 00 04
*Mar 1 12:23:52.868: [74]PPPoE 74: Destroying R:cc04.27d8.0000 L:cc00.27d8.0010 Fa1/0
*Mar 1 12:23:52.872: [74]PPPoE 74: AAA account stopped
LAC#
LAC#
*Mar 1 12:24:12.908: PPPoE 0: I PADI R:cc04.27d8.0000 L:ffff.ffff.ffff Fa1/0
FF FF FF FF FF FF CC 04 27 D8 00 00 88 63 11 09
00 00 00 0C 01 01 00 00 01 03 00 04 64 7C D5 1C ...
*Mar 1 12:24:12.912: Service tag: NULL Tag
*Mar 1 12:24:12.912: PPPoE 0: O PADO, R:cc00.27d8.0010 L:cc04.27d8.0000 Fa1/0
CC 04 27 D8 00 00 CC 00 27 D8 00 10 88 63 11 07
00 00 00 27 01 01 00 00 01 03 00 04 64 7C D5 1C ...
LAC#
*Mar 1 12:24:14.952: PPPoE 0: I PADR R:cc04.27d8.0000 L:cc00.27d8.0010 Fa1/0
CC 00 27 D8 00 10 CC 04 27 D8 00 00 88 63 11 19
*Mar 1 12:24:14.956: Service tag: NULL Tag
*Mar 1 12:24:14.956: PPPoE : encap string prepared
*Mar 1 12:24:14.956: [75]PPPoE 75: Access IE handle allocated
*Mar 1 12:24:14.956: [75]PPPoE 75: pppoe SSS switch updated
*Mar 1 12:24:14.956: [75]PPPoE 75: AAA unique ID allocated
*Mar 1 12:24:14.960: [75]PPPoE 75: No AAA accounting method list
*Mar 1 12:24:14.960: [75]PPPoE 75: Service request sent to SSS
*Mar 1 12:24:14.960: [75]PPPoE 75: Created, Service: None R:cc00.27d8.0010 L:cc04.27d8.0000 Fa1/0
*Mar 1 12:24:14.968: [75]PPPoE 75: State NAS_PORT_POLICY_INQUIRY Event MORE_KEYS
*Mar 1 12:24:14.968: [75]PPPoE 75: O PADS R:cc04.27d8.0000 L:cc00.27d8.0010 Fa1/0
CC 04 27 D8 00 00 CC 00 27 D8 00 10 88 63 11 65
00 4B 00 27 01 01 00 00 01 03 00 04 64 7C D5 1C ...
*Mar 1 12:24:14.976: [75]PPPoE 75: O
02 D1 39 EC
*Mar 1 12:24:14.980: [75]PPPoE 75: State PPP_START Event DYN_BIND
*Mar 1 12:24:14.984: [75]PPPoE 75: data path set to PPP
*Mar 1 12:24:15.092: [75]PPPoE 75: O
*Mar 1 12:24:15.132: [75]PPPoE 75: O
*Mar 1 12:24:15.140: [75]PPPoE 75: O
*Mar 1 12:24:15.164: [75]PPPoE 75: O
*Mar 1 12:24:15.188: [75]PPPoE 75: O
*Mar 1 12:24:15.204: [75]PPPoE 75: O
*Mar 1 12:24:15.248: [75]PPPoE 75: O
*Mar 1 12:24:15.268: [75]PPPoE 75: O
*Mar 1 12:24:15.288: [75]PPPoE 75: O
*Mar 1 12:24:15.324: [75]PPPoE 75: O
*Mar 1 12:24:15.340: [75]PPPoE 75: O
*Mar 1 12:24:15.364: [75]PPPoE 75: O
*Mar 1 12:24:15.384: [75]PPPoE 75: O
*Mar 1 12:24:15.404: [75]PPPoE 75: O
*Mar 1 12:24:15.424: [75]PPPoE 75: O
*Mar 1 12:24:15.444: PPPoE 75: I PADT R:cc04.27d8.0000 L:cc00.27d8.0010 Fa1/0
00 4B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ...
*Mar 1 12:24:15.448: [75]PPPoE 75: O
C0 21 05 01 00 04
*Mar 1 12:24:15.448: [75]PPPoE 75: Destroying R:cc04.27d8.0000 L:cc00.27d8.0010 Fa1/0
*Mar 1 12:24:15.452: [75]PPPoE 75: AAA account stopped
WISH TO ABOVE INFO help to solve the issue ,
note that the tunnel is not up :
LAC#sh vpdn tunnel
%No active L2F tunnels
%No active L2TP tunnels
%No active PPTP tunnels
%No active PPPoE tunnels
LAC#
regards
Ahmad
