Help in selecting a switch
cowan
I am needing to expand a proof-of-concept system that sends scientific data as multicast messages at the full line speed of a 10gb connection.  There are currently two rack computers with Intel X520-DA2 10Gbe cards, connected with a direct attach cable.  Now I want to add a third machine, so need to purchase a switch.  Everything will live in the same rack, and I won't have a use for very many more ports on the switch (not more than 6).  I just need it to intelligently handle the routing of multicast messages (IGMP snooping).
I would appreciate advice on what switch to buy, plus any other add-ons I might need.  My experience is in software development instead of networking, so I'm out of my element when it comes to selecting the appropriate hardware.
Thanks for your help.
Bruce
Reza Sharifi
Hi Bruce,
If you are looking to 10Gig, the 4900 may be a good device for you.  You can get 2 4 port wire speed 10Gig fiber cards for it
Have a look at the datasheet
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6021/ps9310/Data_Sheet_Cat_4900M.html
Reza
