Help in tracing VRF route
mahesh18
Level 6
Level 6
                   Hi Everyone,
From switch i am tracing destination route.
When i do traceroute it shows
traceroute 192.168.100.188
Tracing the route to 192.168.100.188
VRF info: (vrf in name/id, vrf out name/id)
  1 192.168.100.188 0 msec 0 msec 0 msec
When i do  ping to IP  it shows it learned it via  vlan 100.
When i do sh ip vrf int it does not show vlan 100.
But source vlan has vrf.
What should i check next?
Mahesh
Message was edited by: mahesh parmar
2 Accepted Solutions
Hi Mahesh,
Yes you are right. The interface X is a part of the VRF RC. And to check the destination IP you can use the command sh ip ro vrf RC.
***********Plz do rate this post if you find it helpful*************************
Thanks & Regards,
Vignesh R P
Hi Mahesh,
To check the destination IP should i run this command
Yes, when you create a vrf you need to add the name of the vrf in the show commands.  For example:
if you issue "sh ip route" this will show you all the interfaces, vlans, routes in global routing table.  If you want to see routes, vlans, etc.. in a specific vrf then you issue this command:
sh ip route vrf RC
Reza
5 Replies 5
Reza Sharifi
Hi Mahesh,
Can you post "sh run" from the switch?
Do you have any VRFs configured on the switch?
Reza
Hi Reza,
Unfortunately i can not put sh run here.
Yes we do have vrf on switch.
Source SVI  is on this Switch.I am tracing destination from this switch.
Say source svi is x .
when i do sh ip vrf int then it shows me the
interface        IP                               VRF
x                  192.168.x.x                  RC
Does this mean that this vlan is using VRF  right?
SW1# sh ip route vrf RC ?
MAhesh
Hi Mahesh,
Thanks & Regards,
Vignesh R P
Hi Mahesh,
sh ip route vrf RC
Reza
Hi Reza & Vignesh,
Many thanks for replying to my questions.
Best regards
MAhesh
