Help Inter-Vlan routing with 3750x!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
09-17-2016 10:54 AM - edited 03-08-2019 07:28 AM
I have set up a vlan on my network and cannot route trafic from the new vlan108 to vlan1
my laptop is connected to port gi1/0/18 (the vlan 108 access port and i cannot ping 10.2.244.246 the vlan1 interface ip)
ip routing is on (pic 1)
the interfaces are up (pic 2)
vlan ints are assigned to ports (pic 3)
the vlan exists (pic4)
the vlan interfaces have ip addresses (pic 5)
there is no gateway to a router, this is not a public network.
my default gateway is configured properly (pic 6)
according to all documentation i have read this should work....... but it does not
also
3750x is on ip services
12.2.58 se2
please help!!!!
- Labels:
LAN Switching
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-17-2016 12:32 PM
On your screenshots, the vlan 108 is configured on G1/0/18 but this interface seems to be down based on your pic2 file.
Could you check it please?
PS: Please don't forget to rate and mark as correct answer if this answered your question
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-17-2016 01:18 PM
sorry when i took the screen shot, i was unplugged from that port and remotely logged in.
i am currently plugged into port 1/0/18 and have updated the picture
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-18-2016 12:47 PM
Ok before continuing could you answer Paul Driver post?
Francesco
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-18-2016 03:04 AM
Hello
Can you ping the host from the switch sourced from vlan 1
Do you have any software firewall enabled on the host
Can you post the arp table from the switch after trying to ping the host
show ip arp
res
Paul
Kind Regards
Paul
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-19-2016 05:27 AM
No I was not able to ping the host from the switch. Two devices on vlan 8 can ping eachother, but nothing outside the vlan.
so it seems the vlan is working and doing its job segregating traffic.
firewalls are disabled.
Sadly I no longer have access to the switch(commissioning period is over, the vlan migration was postponed), but arp tables looked good the last time i checked it.
We had chalked up this error to a firmware bug.
The switch is running 12.2.58 and someone found a supporting piece of documentation that said, if ip routing is enabled for the first time the switch will need to be reset. which was not an option for us, since we were not cleared for network outages.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-20-2016 06:22 AM
please advise with the full IOS name you have , is it IP Base or IP services .... ?
