Help - L2 redundancy config?
accurisit
As per the attached diagram:
How do I configure the 2 ports on the 3560 (Ports 6 & 7) and the connected ports on each of the 2960 switches (Port 25) to provide redundancy.
If the uplink from Switch A dies then I need the traffic to flow through the trunk and utilise the uplink on Switch B with minimal delay (milliseconds).
Many thanks
Simon...
Message was edited by: Simon Scott - Updated Diagram
9 Replies 9
Reza Sharifi
Are the servers connected to both 2960s using Etherchannel?  If that is the case you can't have an Etherchannel with 2 links, one link connecting to one 2960 and the other one to the other 2960. If these are 2960 S series switches, you can stack them and then the Etherchannel will work fine since both switches logically would look as one.
The switches are basic L2 2960 models so no option to Stack them.
I've amended the diagram to avoid confusion over 'Redundancy' and also to amend the Subnet Mask of the 3560.
If I remove the uplink cable from Switch A it takes 30 to 50 seconds for the Uplink from Switch B to become active
But...
If the uplink cabled from Switch B is removed first, then the Uplink cable from Switch A is removed followed by the Uplink cable from Switch B replaced, the connection comes back immediately.
I've added 'spanning-tree port fast' on the 2 uplink ports on the 3560 but no difference.
Any help would be gratefully received.
Simon...
you should use RPVST+ on all switches  instead of PVST+ (which you are surely using from the 50 sec downtime you described) with the command spanning-tree mode rapid.
Do this during a scheduled  period because it will cause some downtime.
Can you also provide the output from sh sapnning-tree vlan 10 on the 3 switches.
Regards.
Alain
Thanks Alain,
CISCO 3560 SWITCH
Cisco3560#sh spanning-tree vlan 10
VLAN1810
  Spanning tree enabled protocol rstp
  Root ID    Priority    34578
             Address     3cdf.1ecc.7980
             This bridge is the root
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    34578  (priority 32768 sys-id-ext 10)
             Aging Time 300
Interface        Role Sts Cost      Prio.Nbr Type
Gi0/6            Desg FWD 4         128.6    P2p Peer(STP)
Gi0/7            Desg FWD 4         128.7    P2p Peer(STP)
Gi0/17           Desg FWD 19        128.17   P2p
Gi0/21           Desg FWD 19        128.21   P2p
Gi0/22           Desg FWD 19        128.22   P2p
Gi0/23           Desg FWD 19        128.23   P2p
Gi0/24           Desg FWD 19        128.24   P2p
Cisco3560#
CISCO 2960 SWITCH A
co15-pri-sw#sh spanning-tree vlan 10
VLAN1810
             Cost        4
             Port        26 (GigabitEthernet0/2)
             Address     5897.1e4d.3500
             Aging Time  300 sec
Fa0/3               Desg FWD 19        128.3    P2p
Fa0/4               Desg FWD 19        128.4    P2p
Gi0/1               Altn BLK 4         128.25   P2p
Gi0/2               Root FWD 4         128.26   P2p
co15-pri-sw#
CISCO 2960 SWITCH B
co15-sec-sw#sh spanning-tree vlan 10
VLAN1810
             Cost        4
             Address     5478.1a96.d980
             Aging Time  300 sec
Gi0/1               Desg FWD 4         128.25   P2p
co15-sec-sw#
You already have RPVST+, did you make the change already ?
can you post sh cdp nei on the 2960s and sh int trunk.
Regards.
Alain
I already made the change.
CISCO 2960 SWITCH A
co15-pri-sw#sh cdp nei
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
                  D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
co15-sec-sw.alcatel-lucent.com
                 Gig 0/1           162              S I   WS-C2960- Gig 0/1
Cisco3560        Gig 0/2           154             R S I  WS-C3560G Gig 0/6
co15-pri-sw#sh int trunk
Port        Mode             Encapsulation  Status        Native vlan
Gi0/1       on               802.1q         trunking      1
Port        Vlans allowed on trunk
Gi0/1       10,50
Port        Vlans allowed and active in management domain
Gi0/1       10,50
Port        Vlans in spanning tree forwarding state and not pruned
Gi0/1       50
co15-pri-sw#
CISCO 2960 SWITCH B
co15-sec-sw#sh cdp nei
Cisco3560        Gig 0/2           153             R S I  WS-C3560G Gig 0/7
co15-pri-sw.alcatel-lucent.com
                 Gig 0/1           164              S I   WS-C2960- Gig 0/1
co15-sec-sw#sh int trunk
Gi0/1       10,50
Gi0/1       10,50
Gi0/1       10,50
co15-sec-sw#
ok so now you should see less downtime  for failover ? don't enable Portfast on the trunk links between the 2 2960s as well as on the uplink ports.
Regards.
Alain
It's down to 35seconds - Is that about the best I'm going to get?
Simon...
VLAN1810
             Aging Time 300
For your 3560 te 2960s are running PVST+ but they are configured  for RPVST+.
Can you reload them to see if you still have the same behaviour ?
Regards.
Alain
