Help limiting throughput by IP address- Cisco 831
brianjp2472
I have a cisco 831 with about 40 users behind it. I need to limit throughput to certain stations by IP address. Is this possible? Using CAR maybe? My config is below:
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
no service dhcp
hostname xxxxx
enable secret xxx
enable password xxx
username admin password xxx
ip subnet-zero
ip domain name xxxxx
ip name-server x.x.x.x
ip dhcp excluded-address 10.10.10.1
ip dhcp pool CLIENT
import all
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
lease 0 2
ip dhcp pool xxxxx
ip audit notify log
ip audit po max-events 100
ip ssh source-interface Ethernet0
ip address-pool dhcp-pool
vpdn enable
vpdn-group pppoe
request-dialin
protocol pppoe
interface Ethernet0
ip address 10.10.10.1 255.255.255.0
ip nat inside
no cdp enable
hold-queue 32 in
hold-queue 100 out
interface Ethernet1
ip address dhcp
ip nat outside
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxxxxx
ppp chap password xxx
ppp pap sent-username xxxx password xxx
ip nat inside source list 101 interface Dialer1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
access-list 101 permit ip host 10.10.10.8 any
access-list 101 permit ip host 10.10.10.36 any
access-list 101 permit ip host 10.10.10.39 any
access-list 101 permit ip host 10.10.10.54 any
access-list 101 permit ip host 10.10.10.55 any
access-list 101 permit ip host 10.10.10.63 any
access-list 101 permit ip host 10.10.10.78 any
access-list 101 permit ip host 10.10.10.85 any
access-list 101 permit ip host 10.10.10.90 any
access-list 101 permit ip host 10.10.10.91 any
access-list 101 permit ip host 10.10.10.92 any
access-list 101 permit ip host 10.10.10.102 any
access-list 101 permit ip host 10.10.10.116 any
access-list 101 permit ip host 10.10.10.123 any
access-list 101 permit ip host 10.10.10.126 any
access-list 101 permit ip host 10.10.10.127 any
access-list 101 permit ip host 10.10.10.134 any
access-list 101 permit ip host 10.10.10.144 any
access-list 101 permit ip host 10.10.10.158 any
line con 0
exec-timeout 120 0
no modem enable
stopbits 1
line aux 0
stopbits 1
line vty 0 4
exec-timeout 120 0
login local
length 0
scheduler max-task-time 5000
end
Any help is appreciated.
Istvan_Rabai
Level 7
Level 7
Hi Brian,
Generally, rate limiting is possible with qos acls, class-maps and policy-maps.
But I have no knowledge about the scale of qos features in Cicso 831 routers.
I suggest you going in this direction with your search.
Cheers:
Istvan
