Help me please with upgrading IOS on standby supervisor (Catalyst 4510)
Segey Mikhailov
Hello!
Now I have RPR mode because supervisors don't have the same IOS.
I attached the files with output of some commands for better understanding.
Ganesh Hariharan
Hi ,
Check out the following link for upgardation of Sup with brief details hope this help your query !!
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.1/12ew/configuration/guide/RPR.html#wp1104060
Ganesh.H
6 Replies 6
Ganesh Hariharan
Hi ,
Ganesh.H
vvasisth
if you can access the bootflash of standby sup then copy the ios to the bootflash and reload the standby sup
when its booting console into it and use ctrl + break to make is fall in rommon mode
then make it boot from the IOS we have copied
or if you have a external flash card make sure u have the required ios on it then follow the same steps of brining the sup to rommon mode and make it boot from the new ios
check the below given link to  do the same :-
http://www.cisco.com/en/US/products/hw/switches/ps663/products_configuration_example09186a0080094ecf.shtml
regards,
Varun
Some questions -
Now i have -
Current Processor Information :
               Active Location = slot 6
        Current Software state = ACTIVE
       Uptime in current state = 1 year, 1 week, 4 days, 18 hours, 25 minutes
                 Image Version = Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-IPBASEK9-M), Version 12.2(46)SG, RELEASE
                          BOOT = bootflash:cat4500e-ipbasek9-mz.122-46.SG.bin,1;
        Configuration register = 0x2101
Peer Processor Information :
              Standby Location = slot 5
        Current Software state = STANDBY COLD
       Uptime in current state = 1 week, 1 day, 17 hours, 53 minutes
                 Image Version = Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-IPBASE-M), Version 12.2(40)SG, RELEASE SOFTWARE
Boot variables are identical. As i correctly understood -  the standby supervisor in the RPR mode doesn't use IOS, included in it's boot variable. And only switchover command will make it active and force it to boot with needed IOS. Am i right?
Hi ,
check out the below link it will clear your query for Configuring Supervisor Engine Redundancy on the Catalyst 4507R.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.1/13ew/configuration/guide/RPR.html#wp1097897
Hope that helps !!
Ganesh.H
dkempthorne
Level 4
Level 4
A cold standby processor is booted, but the failover process requires reload for it to take over control. If you're looking for SSO mode, you may need to simply configure it:
conf t
redundancy
mode sso
Segey Mikhailov
All what i need was to run command switchover a twice. And the process of booting with register 0x2
now i have sso mode with the same IOS on both supervisors.
