Help me please!
thanhtuong30789
I wan to connect a diagram (below).
But it not operation
Can you help me please!
Thanks.
thanhtuong30789
chrihussey
What is the problem? Will the link not come up?
What type SFPs, and fiber are you using and what is the distance between the two sites?
Have you tried flipping the fibers on onbe side?
Can you supply configs?
In diagram R2911 on site 1 connect to R2911 on site e by gi0/0/0 (on both R2911)
In Vwic3-2mft-T1/E1, i'm using E1 type and connect to PBX analog
Cable "single mode" and distance 3km
When connect R2911 to PBX analog, between E1 and PBX analog had sync signal
With SFPs is GLC-LH-SMD Cisco
I want call from PBX analog on site 1 to site 2?
Can you help me view config.txt on attack file.
