Questions about Cisco nexus 5596 or 5548
ecc
Hello Everyone,
I want to buy a nexus 5596 or 5548 but before i want some clarifications.
Does nexus 5596 or 5548 need the L3 module to do routing or the module is for improvement in L3?
What i read so far is that you can do L3 on those nexus swithes but limited, in case you want full L3 like BGP you need to buy the Enterprise license.
Can someone clarify how the nexus L3 with BGP works? What i need to buy? Do I need the switch and the enterprise license or I have to buy the module separete too?
Please let me know.
2 Accepted Solutions
Austin Sabio
Level 4
Level 4
For routing capabilty a L3 module is needed additionally for BGP support an enterprise license is required.
Licenses:
Cisco Nexus 5500 Layer 3 Enterprise Software License
Chassis
N55-LAN1K9
Full EIGRP, OSPF with scalability up to 8000 routes, BGP; maximum routes supported by Layer 3 hardware: 8000 entries; uRPF
N55-LAN1K9(=)
Hardware: *per platform 5548 and 5596*
N55-D160L3(=)
Nexus 5548 Layer 3 Daughter Card
N55-D160L3-V2(=)
Nexus 5548 Layer 3 Daughter Card, version 2
N55-M160L3(=)
Nexus 5596 Layer 3 Expansion Module
N55-M160L3-V2(=)
Nexus 5596 Layer 3 Expansion Module, version 2
**Nexus switch 5548/5596+ Layer 3 card/module+Enterprise license**
BGP Configuration:
Basic BGP:
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/unicast/5_0_3_N1_1/Cisco_n5k_layer3_ucast_cfg_rel_503_N1_1/l3_bgp.html
Adv BGP:
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/unicast/5_0_3_N1_1/Cisco_n5k_layer3_ucast_cfg_rel_503_N1_1/l3_advbgp.html
I hope this helps. Good luck!
Mark Malone
Hey
The l3 license is included in the l3 module when you but it but you need to speciy which basic or enterprise, without it its only an l2 switch, if you buy it with basic license i think its limited to few hundred routes but with enterprise its thousands , think about 8000 in enterprise
Austin Sabio
Level 4
Level 4
Licenses:
Chassis
N55-LAN1K9
N55-LAN1K9(=)
N55-D160L3(=)
N55-D160L3-V2(=)
N55-M160L3(=)
N55-M160L3-V2(=)
BGP Configuration:
Basic BGP:
Adv BGP:
Mark Malone
Hey
Thanks for your help.
