Help Needed: Policy Routing Not Forward Traffic
Sabby0115
Hello Friends
Referring to my topology, I have configured PBR on Schroeder Router, which supposed to do traffic control for telnet & ftp. Telnet traffic should flow through Lucy Router & FTP Traffic should go to Pigpen.
But it is not happening. Here is the configuration of  Schroeder Router.
interface FastEthernet0/0
ip address 172.16.1.254 255.255.255.0
ip policy route-map PATH_CONTROL
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0
ip address 172.16.2.2 255.255.255.0
serial restart-delay 0
interface Serial1/1
ip address 172.16.3.2 255.255.255.0
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
router ospf 1
router-id 5.5.5.5
log-adjacency-changes
network 0.0.0.0 255.255.255.255 area 0
ip http server
no ip http secure-server
access-list 105 permit tcp 172.16.1.0 0.0.0.255 eq telnet any
access-list 106 permit tcp 172.16.1.0 0.0.0.255 eq ftp any
access-list 106 permit tcp 172.16.1.0 0.0.0.255 eq ftp-data any
route-map PATH_CONTROL permit 10
match ip address 105
set ip next-hop 172.16.2.1
route-map PATH_CONTROL permit 20
match ip address 106
set ip next-hop 172.16.3.1
Debug result on Schroeder
Schroeder# debug ip policy
Policy routing debugging is on
*Mar 1 00:01:56.699: IP: s=172.16.1.1 (FastEthernet0/0), d=172.16.6.1, len 44, FIB policy rejected(no match) - normal forwarding
*Mar 1 00:01:56.871: IP: s=172.16.1.1 (FastEthernet0/0), d=172.16.6.1, len 40, FIB policy rejected(no match) - normal forwarding
*Mar 1 00:01:56.875: IP: s=172.16.1.1 (FastEthernet0/0), d=172.16.6.1, len 49, FIB policy rejected(no match) - normal forwarding
*Mar 1 00:01:56.879: IP: s=172.16.1.1 (FastEthernet0/0), d=172.16.6.1, len 40, FIB policy rejected(no match) - normal forwarding
*Mar 1 00:01:57.043: IP: s=172.16.1.1 (FastEthernet0/0), d=172.16.6.1, len 43, FIB policy rejected(no match) - normal forwarding
*Mar 1 00:01:57.047: IP: s=172.16.1.1 (FastEthernet0/0), d=172.16.6.1, len 43, FIB policy rejected(no match) - normal forwarding
*Mar 1 00:01:57.051: IP: s=172.16.1.1 (FastEthernet0/0), d=172.16.6.1, len 49, FIB policy rejected(no match) - normal forwarding
*Mar 1 00:01:57.307: IP: s=172.16.1.1 (FastEthernet0/0), d=172.16.6.1, len 40, FIB policy rejected(no match) - normal forwarding
*Mar 1 00:05:16.871: IP: s=172.16.1.2 (FastEthernet0/0), d=172.16.7.1, len 1024, FIB policy rejected(no match) - normal forwarding
*Mar 1 00:05:17.087: IP: s=172.16.1.2 (FastEthernet0/0), d=172.16.7.1, len 1024, FIB policy rejected(no match) - normal forwarding
*Mar 1 00:05:17.307: IP: s=172.16.1.2 (FastEthernet0/0), d=172.16.7.1, len 1024, FIB policy rejected(no match) - normal forwarding
*Mar 1 00:05:17.555: IP: s=172.16.1.2 (FastEthernet0/0), d=172.16.7.1, len 1024, FIB policy rejected(no match) - normal forwarding
*Mar 1 00:05:17.775: IP: s=172.16.1.2 (FastEthernet0/0), d=172.16.7.1, len 1024, FIB policy rejected(no match) - normal forwarding
Best Regards
Sabby
2 Accepted Solutions
John Blakley
Sabby,
Your source port will be a high port, but the destination will be ports 20, 21, and 23. Try changing your acls to the following and retest:
access-list 105 permit tcp 172.16.1.0 0.0.0.255 any eq telnet
access-list 106 permit tcp 172.16.1.0 0.0.0.255 any eq 20
access-list 106 permit tcp 172.16.1.0 0.0.0.255 any eq 21
HTH,
John
HTH, John *** Please rate all useful posts ***
PolymorphismIce
      You donot configure the correct ACL, you must restrict the destination port not the source port.
     example :
     access-list 101 permit tcp host x.x.x.x source-port host x.x.x.x destination-port
John Blakley
Sabby,
HTH,
John
Hi John
I changed the config  & now PBR is in action.
Thanks & Regards
Sabby
PolymorphismIce
     example :
Sabby0115
I am using a book & doing all the labs as shown but i dont know how he get the result with same config(bit confuse). I dont understand, I am doing something wrong or this book hav issue with this config.
Here is the screen shot of the page.
Sabby
