Help needed with EIGRP Config
Bob Landis
All,
I'm having an issue with eigrp across one of our remote sites and was hoping someone could help me figure out what I am doing wrong.  As you can see in the attached diagram, we have three separate buildings with access switches - Admin, Ops, and Fleet. Each building has five local vlans - 500, 800, 810, 820, and 830. Each access layer switch is routed to the distribution layer switch at the Nexus building via an etherchannel. The Nexus building has a trunk port connection via an EP-LAN from a local ISP to a 6509E switch at our main office. The EP-LAN connection is strictly a trunk port passing all vlan tags and cannot be configured as a routed port.
At the main site with the 6509E, we have a vlan 4 configured that is for server management.  Server-1 in the diagram is configured with an ip address in vlan 4 of 192.168.4.200.  We would like to be able to use the same IP scope for servers located at the Nexus building as well - for example, Server-2 in the diagram is configured with an ip address of 192.168.4.201.  We have added the network 192.168.4.0 0.0.0.255 to the EIGRP configuration on both the Nexus campus switch as well as the 6509E, but we are unable to ping or access Server-1 from the Nexus switch, Ops switch, Admin Switch, or Fleet Switch.  However, from the 6509E I am able to ping Server-2 just fine.
The goal is for all subnets to be reachable from all locations - for example, the 6509E should be able to access all hosts on each of the five subnets at the Admin building, Ops Building, Fleet Building and the same should be possible in reverse where each of the buildings should be able to access the subnets on the 6509E. The same is true for Server-1 and Server-2 - they should be reachable from all locations.
I'm not sure what we have done wrong in regards to our EIGRP configuration, and we have tried various combinations without success.  Below are the outputs of the ip route and ip eigrp neighbors from each location, along with the corresponding switch configurations.
Any help would be greatly appreciated!
Bob
ADMIN:
C3850X_Admin#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       a - application route
       + - replicated route, % - next hop override
Gateway of last resort is not set
      172.27.0.0/16 is variably subnetted, 4 subnets, 2 masks
C        172.27.132.192/26 is directly connected, Vlan500
L        172.27.132.194/32 is directly connected, Vlan500
D        172.27.133.0/26 [90/3072] via 172.27.132.193, 00:41:03, Vlan500
D        172.27.133.64/26 [90/3072] via 172.27.132.193, 00:41:03, Vlan500
      172.28.0.0/24 is subnetted, 1 subnets
D        172.28.0.0 [90/3072] via 172.27.132.193, 00:41:03, Vlan500
D     192.168.4.0/24 [90/3328] via 172.27.132.193, 00:41:02, Vlan500
C3850X_Admin#sh ip eigrp nei
EIGRP-IPv4 Neighbors for AS(1)
H   Address                 Interface              Hold Uptime   SRTT   RTO  Q  Seq
                                                   (sec)         (ms)       Cnt Num
0   172.27.132.193          Vl500                    14 01:07:31    5   100  0  394
C3850X_Admin#sh ip eigrp int
EIGRP-IPv4 Interfaces for AS(1)
                              Xmit Queue   PeerQ        Mean   Pacing Time   Multicast    Pending
Interface              Peers  Un/Reliable  Un/Reliable  SRTT   Un/Reliable   Flow Timer   Routes
Vl800                    0        0/0       0/0           0       0/0            0           0
Vl810                    0        0/0       0/0           0       0/0            0           0
Vl820                    0        0/0       0/0           0       0/0            0           0
Vl830                    0        0/0       0/0           0       0/0            0           0
Vl500                    1        0/0       0/0           5       0/0           50           0
C3850X_Admin#
OPS:
C3850X_Ops#sh ip route
D        172.27.132.192/26 [90/3072] via 172.27.133.1, 01:09:25, Vlan500
C        172.27.133.0/26 is directly connected, Vlan500
L        172.27.133.2/32 is directly connected, Vlan500
D        172.27.133.64/26 [90/3072] via 172.27.133.1, 01:09:25, Vlan500
D        172.28.0.0 [90/3072] via 172.27.133.1, 01:09:25, Vlan500
D     192.168.4.0/24 [90/3328] via 172.27.133.1, 01:09:24, Vlan500
C3850X_Ops#sh ip eigrp nei
                                                   (sec)         (ms)       Cnt Num
0   172.27.133.1            Vl500                    11 01:09:30    4   100  0  395
C3850X_Ops#sh ip eigrp int
Vl500                    1        0/0       0/0           4       0/0           50           0
C3850X_Ops#
Fleet:
C3850X_Fleet#sh ip route
D        172.27.132.192/26 [90/3072] via 172.27.133.65, 01:11:33, Vlan500
D        172.27.133.0/26 [90/3072] via 172.27.133.65, 01:11:33, Vlan500
C        172.27.133.64/26 is directly connected, Vlan500
L        172.27.133.66/32 is directly connected, Vlan500
D        172.28.0.0 [90/3072] via 172.27.133.65, 01:11:33, Vlan500
D     192.168.4.0/24 [90/3328] via 172.27.133.65, 01:11:33, Vlan500
C3850X_Fleet#sh ip eigrp nei
                                                   (sec)         (ms)       Cnt Num
0   172.27.133.65           Vl500                    10 01:11:40    7   100  0  392
C3850X_Fleet#sh ip eigrp int
Vl500                    1        0/0       0/0           7       0/0           50           0
C3850X_Fleet#
NEXUS BUILDING:
Nexus#sh ip route
      172.27.0.0/16 is variably subnetted, 6 subnets, 2 masks
C        172.27.132.192/26 is directly connected, Port-channel1
L        172.27.132.193/32 is directly connected, Port-channel1
C        172.27.133.0/26 is directly connected, Port-channel2
L        172.27.133.1/32 is directly connected, Port-channel2
C        172.27.133.64/26 is directly connected, Port-channel3
L        172.27.133.65/32 is directly connected, Port-channel3
      172.28.0.0/16 is variably subnetted, 2 subnets, 2 masks
C        172.28.0.0/24 is directly connected, Vlan600
L        172.28.0.2/32 is directly connected, Vlan600
D     192.168.4.0/24 [90/3072] via 172.28.0.1, 01:12:26, Vlan600
Nexus#sh ip eigrp nei
                                                   (sec)         (ms)       Cnt Num
3   172.27.133.66           Po3                      12 01:12:34 1600  5000  0  102
2   172.28.0.1              Vl600                    11 01:12:34    4   100  0  117
1   172.27.133.2            Po2                      11 01:12:35    5   100  0  102
0   172.27.132.194          Po1                      12 01:12:35    5   100  0  104
Nexus#sh ip eigrp int
Po3                      1        0/0       0/0        1600       0/0         7992           0
Po2                      1        0/0       0/0           5       0/0           50           0
Po1                      1        0/0       0/0           5       0/0           50           0
Vl600                    1        0/0       0/0           4       0/0           50           0
Nexus#
6509E Site:
6509E_Core#sh ip route
      172.16.0.0/16 is variably subnetted, 2 subnets, 2 masks
C        172.16.24.0/21 is directly connected, Vlan1
L        172.16.24.1/32 is directly connected, Vlan1
      172.27.0.0/26 is subnetted, 3 subnets
D        172.27.132.192 [90/3072] via 172.28.0.2, 01:13:42, Vlan600
D        172.27.133.0 [90/3072] via 172.28.0.2, 01:13:42, Vlan600
D        172.27.133.64 [90/3072] via 172.28.0.2, 01:13:42, Vlan600
L        172.28.0.1/32 is directly connected, Vlan600
      192.168.4.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.4.0/24 is directly connected, Vlan4
L        192.168.4.254/32 is directly connected, Vlan4
6509E_Core#sh ip eigrp nei
                                                   (sec)         (ms)       Cnt Num
0   172.28.0.2              Vl600                    14 01:13:48    6   100  0  396
6509E_Core#sh ip eigrp int
Vl600                    1        0/0       0/0           6       0/0           50           0
Vl4                      0        0/0       0/0           0       0/0          556           0
6509E_Core#
Admin Config:
version 15.2
service compress-config
hostname C3850X_Admin
boot-start-marker
boot-end-marker
no aaa new-model
vtp mode transparent
ip dhcp excluded-address 172.27.132.193 172.27.132.200
ip dhcp excluded-address 172.27.80.1 172.27.80.247
ip dhcp excluded-address 172.27.81.1 172.27.81.247
ip dhcp excluded-address 172.27.82.1 172.27.82.31
ip dhcp excluded-address 172.27.83.1 172.27.83.31
ip dhcp pool WAN_VLAN_Pool
 network 172.27.132.192 255.255.255.192
 default-router 172.27.132.193
 dns-server 172.16.24.8 172.16.24.42
 domain-name site.local
ip dhcp pool Management
 network 172.27.80.0 255.255.255.0
 default-router 172.27.80.1
ip dhcp pool Video
 network 172.27.81.0 255.255.255.0
 default-router 172.27.81.1
ip dhcp pool Voice
 network 172.27.82.0 255.255.255.0
 default-router 172.27.82.1
 option 150 ip 172.20.0.2
ip dhcp pool Data
 network 172.27.83.0 255.255.255.0
 default-router 172.27.83.1
ip cef
no ipv6 cef
errdisable recovery cause bpduguard
errdisable recovery cause link-flap
errdisable recovery cause psecure-violation
errdisable recovery interval 600
spanning-tree mode rapid-pvst
spanning-tree loopguard default
vlan internal allocation policy ascending
vlan 500
 name WAN_VLAN
vlan 800
 name Management
vlan 810
 name Video
vlan 820
 name Voice
vlan 830
 name Data
interface Port-channel1
 switchport access vlan 500
interface GigabitEthernet0/0
 shutdown
 media-type rj45
 negotiation auto
interface GigabitEthernet0/1
 media-type rj45
 negotiation auto
 channel-group 1 mode on
interface GigabitEthernet0/2
 media-type rj45
 negotiation auto
interface Vlan500
 ip address 172.27.132.194 255.255.255.192
interface Vlan800
 ip address 172.27.80.1 255.255.255.0
interface Vlan810
 ip address 172.27.81.1 255.255.255.0
interface Vlan820
 ip address 172.27.82.1 255.255.255.0
interface Vlan830
 ip address 172.27.83.1 255.255.255.0
router eigrp 1
 network 172.27.80.0 0.0.0.255
 network 172.27.81.0 0.0.0.255
 network 172.27.82.0 0.0.0.255
 network 172.27.83.0 0.0.0.255
 network 172.27.132.192 0.0.0.63
ip forward-protocol nd
no ip http server
no ip http secure-server
logging origin-id string Switchsyslog
logging host 172.20.0.2
control-plane
OPS Config:
version 15.2
hostname C3850X_Ops
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp excluded-address 172.27.133.1 172.27.133.8
ip dhcp excluded-address 172.27.84.1 172.27.84.247
ip dhcp excluded-address 172.27.85.1 172.27.85.247
ip dhcp excluded-address 172.27.86.1 172.27.86.31
ip dhcp excluded-address 172.27.87.1 172.27.87.31
 network 172.27.133.0 255.255.255.192
 default-router 172.27.133.1
 network 172.27.84.0 255.255.255.0
 default-router 172.27.84.1
ip dhcp pool Video
 network 172.27.85.0 255.255.255.0
 default-router 172.27.85.1
ip dhcp pool Voice
 network 172.27.86.0 255.255.255.0
 default-router 172.27.86.1
ip dhcp pool Data
 network 172.27.87.0 255.255.255.0
 default-router 172.27.87.1
ip cef
no ipv6 cef
vlan 500
 name WAN_VLAN
vlan 800
 name Management
vlan 810
 name Video
vlan 820
 name Voice
vlan 830
 name Data
interface Port-channel2
 shutdown
 media-type rj45
 negotiation auto
 description Uplink to Nexus
 media-type rj45
 negotiation auto
 channel-group 2 mode on
 media-type rj45
 negotiation auto
interface Vlan500
 ip address 172.27.133.2 255.255.255.192
interface Vlan800
 ip address 172.27.84.1 255.255.255.0
interface Vlan810
 ip address 172.27.85.1 255.255.255.0
interface Vlan820
 ip address 172.27.86.1 255.255.255.0
interface Vlan830
 ip address 172.27.87.1 255.255.255.0
router eigrp 1
 network 172.27.84.0 0.0.0.255
 network 172.27.85.0 0.0.0.255
 network 172.27.86.0 0.0.0.255
 network 172.27.87.0 0.0.0.255
 network 172.27.133.0 0.0.0.63
no ip http server
control-plane
Fleet Config:
version 15.2
hostname C3850X_Fleet
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp excluded-address 172.27.133.65 172.27.133.72
ip dhcp excluded-address 172.27.88.1 172.27.88.247
ip dhcp excluded-address 172.27.89.1 172.27.89.247
ip dhcp excluded-address 172.27.90.1 172.27.90.31
ip dhcp excluded-address 172.27.91.1 172.27.91.31
 network 172.27.133.64 255.255.255.192
 default-router 172.27.133.65
 network 172.27.88.0 255.255.255.0
 default-router 172.27.88.1
ip dhcp pool Video
 network 172.27.89.0 255.255.255.0
 default-router 172.27.89.1
ip dhcp pool Voice
 network 172.27.90.0 255.255.255.0
 default-router 172.27.90.1
ip dhcp pool Data
 network 172.27.91.0 255.255.255.0
 default-router 172.27.91.1
ip cef
no ipv6 cef
vlan 500
 name WAN_VLAN
vlan 800
 name Management
vlan 810
 name Video
vlan 820
 name Voice
vlan 830
 name Data
interface Port-channel3
 shutdown
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 channel-group 3 mode on
 media-type rj45
 negotiation auto
interface Vlan500
 ip address 172.27.133.66 255.255.255.192
interface Vlan800
 ip address 172.27.88.1 255.255.255.0
interface Vlan810
 ip address 172.27.89.1 255.255.255.0
interface Vlan820
 ip address 172.27.90.1 255.255.255.0
interface Vlan830
 ip address 172.27.91.1 255.255.255.0
router eigrp 1
 network 172.27.88.0 0.0.0.255
 network 172.27.89.0 0.0.0.255
 network 172.27.90.0 0.0.0.255
 network 172.27.91.0 0.0.0.255
 network 172.27.133.64 0.0.0.63
no ip http server
control-plane
Nexus Config:
version 15.2
hostname Nexus
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
vlan 4
 name HW_Mgmt
vlan 600
 name Uplink_To_Core
 no switchport
 ip address 172.27.132.193 255.255.255.192
 spanning-tree portfast edge
 spanning-tree link-type point-to-point
 no switchport
 ip address 172.27.133.1 255.255.255.192
 no switchport
 ip address 172.27.133.65 255.255.255.192
 media-type rj45
 negotiation auto
 description Uplink to Admin
 no switchport
 no ip address
 negotiation auto
 no switchport
 no ip address
 negotiation auto
interface GigabitEthernet0/3
 description Uplink to Ops
 no switchport
 no ip address
 negotiation auto
interface GigabitEthernet1/0
 no switchport
 no ip address
 negotiation auto
interface GigabitEthernet1/1
 description Uplink to Fleet
 no switchport
 no ip address
 negotiation auto
interface GigabitEthernet1/2
 no switchport
 no ip address
 negotiation auto
interface GigabitEthernet1/3
 description Uplink to 6509E
 switchport trunk native vlan 600
 switchport mode trunk
 media-type rj45
 negotiation auto
interface GigabitEthernet2/0
 description Server 2
 switchport access vlan 4
 media-type rj45
 negotiation auto
interface Vlan600
 ip address 172.28.0.2 255.255.255.0
router eigrp 1
 network 172.28.0.0 0.0.0.255
 network 192.168.4.0
no ip http server
control-plane
6509E Config:
version 15.2
hostname 6509E_Core
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
vlan 4
 name HW_Mgmt
vlan 600
 name ISP_EPLAN_Uplink
 shutdown
 media-type rj45
 negotiation auto
 description ISP EP-LAN Uplink
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
interface Vlan1
 ip address 172.16.24.1 255.255.248.0
interface Vlan4
 description ***VM-MNGT***
 ip address 192.168.4.254 255.255.255.0
interface Vlan600
 ip address 172.28.0.1 255.255.255.0
router eigrp 1
 network 192.168.4.0
no ip http server
control-plane
Jon Marshall
Your EIGRP configuration on the Nexus is wrong.
If you are routing between the Admin, Ops and Fleet sites to the Nexus then you do not have network statements under the EIGRP configuration for the subnets local to each remote site.
The same applies to the 192.168.4.0/24 subnet ie. you do not have an SVI on the Nexus for this, it is routed on the 6500 so you don't need a network statement for that either.
So on the Nexus you only need network statements for the port channel subnets connecting to the remote sites and for the vlan 600 subnet connecting to the 6500 switch.
I am not sure that is your problem but can you tidy all that up first and then it may be easier to troubleshoot.
Jon
Jon,
I cleaned up the Nexus site eigrp configuration and I am still unable to ping the Server-1 host from any site.  EIGRP configuration on the Nexus site is now as follows:
Nexus#sh run | beg router eigrp
router eigrp 1
Nexus#sh ip route
D     192.168.4.0/24 [90/3072] via 172.28.0.1, 00:01:57, Vlan600
                                                   (sec)         (ms)       Cnt Num
3   172.27.133.2            Po2                      11 00:02:10   11   100  0  128
2   172.27.132.194          Po1                      11 00:02:10   10   100  0  129
1   172.27.133.66           Po3                      11 00:02:10   12   100  0  128
0   172.28.0.1              Vl600                    10 00:02:10 1593  5000  0  146
Po3                      1        0/0       0/0          12       0/0           50           0
Po2                      1        0/0       0/0          11       0/0           50           0
Po1                      1        0/0       0/0          10       0/0           50           0
Vl600                    1        0/0       0/0        1593       0/0         7960           0
Nexus#
Nexus#ping 192.168.4.200
Sending 5, 100-byte ICMP Echos to 192.168.4.200, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Nexus#traceroute ip 192.168.4.200
Tracing the route to 192.168.4.200
VRF info: (vrf in name/id, vrf out name/id)
  1 172.28.0.1 2 msec 3 msec 2 msec
  2  *  *  *
  3  *  *  *
  4  *  *  *
  5  *
Nexus#
Not only can I not access the Server-1 (192.168.4.200) from the Nexus campus, but I cannot access it from any other site.  Below is from the Admin site:
D        172.27.133.0/26 [90/3072] via 172.27.132.193, 00:04:30, Vlan500
D        172.27.133.64/26 [90/3072] via 172.27.132.193, 00:04:30, Vlan500
D        172.28.0.0 [90/3072] via 172.27.132.193, 00:04:30, Vlan500
D     192.168.4.0/24 [90/3328] via 172.27.132.193, 00:04:30, Vlan500
                                                   (sec)         (ms)       Cnt Num
0   172.27.132.193          Vl500                    11 00:04:39   18   108  0  496
Vl500                    1        0/0       0/0          18       0/1           76           0
C3850X_Admin#traceroute ip 192.168.4.200
  1 172.27.132.193 3 msec 3 msec 3 msec
  2 172.28.0.1 4 msec 6 msec 6 msec
  3  *  *  *
  4  *  *  *
  5  *  *  *
  6  *  *  *
  7  *  *  *
  8  *  *  *
  9  *
C3850X_Admin#
Bob
Bob
Presumably the 6500 can ping the server ?
If so then can you check the default gateway on the server to make sure it is correct.
Jon
