Help! No Routing after IP Change
robertstahl
I am a novice with networking; so, if I write something noobish, please forgive and explain. I am using a Cisco 2821 router.
My provider changed my IP address today from:
218.x.x.x /24  with a gateway of 218.x.x.1 /24
to
219.x.x.x /25  with a gateway of 219..x.x.1 /25
I changed the IP address for the interface GE0/0 to the new IP address. I can ping the router no problem from the LAN.
I changed the static route from:
ip route 0.0.0.0 0.0.0.0 218.x.x.1
to
ip route 0.0.0.0 0.0.0.0 219.x.x.1
The router cannot ping the gateway; thus, no Internet.
When I change the static route to the interface:
ip route 0.0.0.0 0.0.0.0 GigabitEthernet 0/0   I am able to ping the gateway, but still not able to access the Internet.
I am running a Windows 2008 network with 2 DNS servers.
It was working fine before the change. Any suggestion before I have to hire someone to fix it?
cadet alain
delete the static route pointing to the interface and reconfigure the one pointing to next-hop then try to clear the arp cache on the router with clear arp interface g0/0.
clear also your dynamic nat translations with clear ip nat trans *.
Regards.
Alain
Thanks Alain!!
Establishing the static route with the interface g0/0, and then entring the optional IP Address of the next hop, did the trick!
Robert
