Help port forward IOS 12.4
tony
a simple port forward:
ip nat inside source static tcp 192.168.0.20 8081 interface Dailer1 8081
i am trying to get to 192.168.0.20:8081 from outside my network..what iam i missing here.
Tony Donn
attached config
I am a Cisco for Dummies case.... Please help me..
6 Replies 6
Paul Preston
Hi Tony,
nat rule looks fine to me, so its most likely a problem with something else like access lists or "ip nat (inside|outside)" commands assigned to interfaces.
Can you paste your running config?
Paul Preston
Proxar IT Ltd. Registered in England and Wales: 6744401- VAT: 942985479
Tubs Hill House, London Road, Sevenoaks, Kent, TN13 1BL
Tel:  (+44) 0844 809 4335
Fax: (+44) 01732 468 574
Mob: (+44) 077 9509 3450
Web: www.proxar.co.uk
Email: paul.preston@proxar.co.uk
Paul Preston
Unit 1, 205 London Road, Sevenoaks, Kent, TN13 1DW
Tel: +44 203 196 6566
Email
Building configuration...
Current configuration : 1880 bytes
version 12.4
hostname Gw1
boot-start-marker
boot-end-marker
enable secret 5
enable password
no aaa new-model
no network-clock-participate slot 1
voice-card 0
dspfarm
no local-bypass
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.0.0 192.168.0.99
ip dhcp pool LAN
   network 192.168.0.0 255.255.255.0
   dns-server 192.231.203.132 192.231.203.3
   default-router 192.168.0.1
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
vpdn enable
interface ATM0/0
no ip address
atm restart timer 300
no atm ilmi-keepalive
bundle-enable
dsl operating-mode auto
bridge-group 1
hold-queue 224 in
pvc 8/35
  pppoe-client dial-pool-number 1
interface FastEthernet0/0
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly
speed auto
full-duplex
no mop enabled
bridge-group 1
interface Serial0/1
no ip address
shutdown
no fair-queue
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication chap callin
ppp chap hostname
ppp chap password 0
router rip
redistribute connected
network 192.168.0.0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
access-list 1 permit 192.168.0.0 0.0.0.255
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipx permit
snmp-server community public RO
control-plane
bridge 1 protocol dec
gatekeeper
shutdown
line con 0
line aux 0
line vty 0 4
password T1fort2
login
end
Gw1#
Reza Sharifi
Tony,
I don't see this statement in your "sh run" add it and test
Tony,
Please use the command below (there is a spelling mistake in the name of the interface in your command):
ip nat inside source static tcp 192.168.0.20 8081 interface Dialer1 8081
Paul Preston
Paul Preston
Email
Good pick up Paul on my spelling..
Reza the config is before i put in ip nat insid..................
I will post current run config. as attachment
I am thinking i need something like ip nat outside source Dialer 1 8081 static tcp 192.168.0.20 8081 but i wouldnt really know..
Good catch Paul.
Tony,
After the interface you can simply type d and then press the tab key, the router will give you the rest.  So you don't have to spell it.
Reza
