Help Regarding c3750-Bandwidth Limitation
pjallipalli
I need some help regarding bandwidth limitation on cisco 3750 switch. This is to be done per VLAN.
Joseph W. Doherty
I recall the later 3750 images support VLAN policing. Have you looked at the 3750 configuration guide's chapter on QoS?
aghaznavi
Level 5
Level 5
Use the srr-queue bandwidth limit on interface configuration command on the ports where heavy traffic is seen. This command may help you limit the bandwidth on VLAN.
Joseph W. Doherty
