Help reqired to config QoS in Cisco 2960 switch
Nirmal Paria
Hi Team,
I am designing QoS on Cisco 2960 Switch.
My requirement:
Q – 1 Should get Shape Bandwidth 10 %
Q – 2 Should get Share Bandwidth 10 %
Q – 3 Should get Share Bandwidth 60 %
Q – 4 Should get Share Bandwidth 20 %
I can configure in following way:
Option 1:
CAT2960(config-if)# srr-queue bandwidth shape 10 0 0 0
CAT2960(config-if)# srr-queue bandwidth share  10 10 60 20
CAT2960(config-if)# priority-queue out
Option 2:
CAT2960(config-if)# srr-queue bandwidth shape 1 0 0 0
CAT2960(config-if)# srr-queue bandwidth share  1 1 6 2
I do not have any Cisco 2960 Switch to verify. Can you please let me know which one correct.
You have any suggestion on this please let me know.
Nirmal
5 Replies 5
Lei Tian
Hi Nirmal,
Both are the same. It is not percentage, it is ratio, so 'srr-queue bandwidth 10 10 60 20' is ame as 'srr-queue bandwidth 1 1 6 2'.
One thing to know is the priority queue is strict priority, which means once you have 'priority-queue out' in place, it will ignore the shape or share bandwidth.This queue will alway be served first until it is empty.
HTH,
Lei Tian
Hi Lei Tian,
Thanks for your quick response. I would have another query on it:
if I do the configuration as below:
Will the queue 1 server in strict priority with 1/10 of total interface bandwidth or how?
Deeply apologize if have already answered my query.
Nirmal
Hi Nirmal,
No, the strict priority queue will not be limited to 1/10. The bandwidth command will be ignored for priority queue.If you want limit the P1 bandwidth to 10%, then you need remove 'priority-queue out' from your interface.
HTH,
Lei Tian
Appreciate your quick support. Thanks once again.
To add to that:-
Priority OVERIDES shape and share
shape over rides share
Mo
