Help required for designing a LAN for networking novice
bradbrad8
I am new to Cisco Packet Tracer and need some help. I have been tasked to do the following:
Design a LAN with three desktops, a switch, server, firewall, wireless access point, router, modem. The three desktops, server, firewall will plug into a switch through Fast Ethernet and then the switch will then plug into the router through Ethernet.
There will be an Ethernet connection between the wireless access point and router, and the router will connect to a DSL modem. The router will provide a static IP wired network/internet connection to the server and desktops. The Wireless Access Point has the role of giving wireless internet networking to a smart device brought in by an employee, of which the wireless network needs a firewall, WPA2-PSK encryption and a passphrase. The wireless network will assign the smart device an IP via DHCP. There needs to be internet access for the computers, server and smart device.
I have attached images of the work I have done so far. If possible I would like to know how I configure the router (internet IP, DNS, gateway, subnet mask)
and WAP (setup wireless network and firewall) to provide internet access and simulate the connection from the router to modem then ISP.
Thank you
Deepak Kumar
Can you share your topology with IP schemes so we can help you better?
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Leo Laohoo
Wrong forum.
This is school work and this line of questioning needs to go to the Cisco Learning Network.
This forum is predominantly used by professionals.  What the professionals do in the "wild" may NOT be acceptable in classrooms (as answers) and there's a strong chance could be deemed as incorrect.
