Nexus N5K-C5672UP ACL question - host or /32 syntax?
mattcisconet
Running version 7.1(0)N1(1a).
So to put it simply, I need to match tcp traffic from a network to a host.
Is this acceptable configuration syntax:
switch(config-acl)#permit tcp 172.16.17.0/24 172.16.154.90/32
or will the switch interpret the /32 host entry as something else entirely?  Would this be the proper syntax instead:
switch(config-acl)#permit tcp 172.16.17.0/24 host 172.16.154.90
I am asking because I used the former /32 syntax, and all heck broke loose.  Something definitely didn't work.
Ok, so I worked with TAC on this and it ended up being a bug. Bug ID CSCus28695. My ACL had a "remark" statement in it, which caused it to match all traffic due to the bug.  I'm also running the ACL on a WCCP redirect list.  Wow, what a crazy thing.
I'm running a Nexus 5672UP with NX-OS 7.1(0)N1(1a). This is fixed in newer releases, or the workaround is just to remove the remark statement.
8 Replies 8
Reza Sharifi
Not sure exactly what you are trying to do but an access list will not be effective unless it is applied to a physical interface or an SVI. If you are trying to allow communications between a host and a network, that is allowed by default on the switch as long as there is a route to that host and there is no access-list blocking it.
Thanks Reza.  I'm only asking about the syntax.  I understand how to apply ACLs to interfaces.
This is the issue:  When you run "show ip access list" the Nexus will output host statements has /32 entries like this:
permit tcp 172.16.17.0/24 172.16.90.47/32
this is the result of inputting this statement "permit tcp 172.16.17.0/24 host 172.16.90.47"
But what if you input this statement, as it appears in the "show" output?
How does the switch interpret that /32?  I think it does not interpret it as a single host, but rather a much broader network subnet.
Anybody know?
thanks.
The Nexus switch will translate both statements as /32 in both show run and sh access-list
In below example, I have one statement with host keyword and one with /32 but sh access-list shows both as /32
show ip access list test
10 permit tcp 172.16.17.0/24 172.16.90.47/32
20 permit tcp 172.16.17.0/24 172.16.90.47/32
and this is from the running config
ip access-list test
Thanks.
That's right, the show run and show access lists with both translate the host entry as /32.
But when actually inputting the access-list statement, I am trying to confirm that when not using the "host" statement, but instead manually inputting a /32 address does the switch interpret that manually entered /32 as a host or as a network?  If it interprets it as a network, what is the reverse mask?  I have a feeling, but I'm not certain, that the switch interprets it as a network - this is because when I applied my access-list statements, I saw traffic that didn't match the /32 statement as a host, but instead seemed to match a much broader network statement.
Hope that makes sense.  Thanks.
/32 (mask 255.255.255.255) is just for that one host and not the whole network.
Yes exactly.  That is what I would have expected.  However in practice that did not appear to be the case.  I wonder if I have run into a bug.  I've opened a TAC case to try to work through it.
