help required in module compatibility
sivakondalarao
Level 6
Level 6
I have 6509 switch with following show version output attached.
Does it support WS-X6748-GE-TX 48-port 10/100/1000 RJ-45 module?
Edison Ortiz
Yes, that blade was designed for Sup720 and you have a Sup720. You should be fine.
http://www.cisco.com/en/US/products/hw/switches/ps708/prod_bulletin0900aecd800f6e27.html
"As the premier modular multilayer Cisco switch for integrated data center switching, the Cisco Catalyst 6500 Series now offers a new, high-performance 48-port 10/100/1000 Ethernet over copper module designed specifically for use with the Cisco Catalyst 6500 Series Supervisor Engine 720 in data center and distribution layer deployments."
___________
Please rate helpful posts.
