12-03-2020 12:03 AM
guidance required regards this
1: Identify the network Region and highlight it with help of drawing tool
2: Use an appropriate IPv4 scheme for the given topology and configure the environment
3: The PC0 and PC7 from network and 1 and 2 respectively, could not communicate outside its network region, while others PCs/Hosts from both networks could communicate.
4: Network 1 hosts should be authenticate via TACACS+ server using path Router 0, Router2, Router4 -> Server. Network 2 hosts should be authenticate via RADIUS server using path Router 0, Router1, Router3 -> Server.
5: TACACS+ use password “tacacslogin” and for RADIUS use “radius login”.'
i have a .pkt file i will share with you in email abdulmajidjamil@hotmail.com and WhatsApp :+923122542308
12-03-2020 12:05 AM
post the zipped Packet Tracer project (.pkt) file here.
12-03-2020 12:10 AM
12-03-2020 12:21 AM
thanks for the file. What specifically do you need help with ?
12-03-2020 12:27 AM
firstly Identify the network Region i have some confusion then i know how to assign ipv4
secondly this point The PC0 and PC7 from network and 1 and 2 respectively, could not communicate outside its network region, while others PCs/Hosts from both networks could communicate.
also this Network 1 hosts should be authenticate via TACACS+ server using path Router 0, Router2, Router4 -> Server. Network 2 hosts should be authenticate via RADIUS server using path Router 0, Router1, Router3 -> Server.
and this TACACS+ use password “tacacslogin” and for RADIUS use “radius login”.'
12-03-2020 12:29 AM
I'll put something together to get you started...
12-03-2020 12:42 AM
sure come on whatsapp
12-03-2020 01:07 AM
12-03-2020 01:44 AM
PC0 AND PC7 ABLE TO COMMUNICATE OUTSIDE THE NETWORK I THINK WE CONFIGURE ACL ON R0
12-03-2020 03:09 AM
exactly, the access list needs to be configured on Router0.
