help subinterface doesnt work
A7M876
Visitor
am try hard to change all configuration but still doesn't work :
router model : 881
router configuration
#show running-config
Building configuration...
Current configuration : 2013 bytes
ip name-server 87.101.202.133
ip name-server 87.101.203.9
ip cef
no ipv6 cef
interface FastEthernet0
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface FastEthernet4
 no ip address
 ip virtual-reassembly in
 duplex auto
 speed auto
interface FastEthernet4.1115
 description " TO ITC Modem "
 encapsulation dot1Q 60
 ip address 87.101.135.100 255.255.255.252
 ip nat outside
interface Vlan1
 description " Conneted To Switch "
 ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 101 interface FastEthernet4.1115 overload
ip route 0.0.0.0 0.0.0.0  0.0.0.0 0.0.0.0 87.101.135.6
access-list 101 deny   ip any 192.168.1.0 0.0.0.255
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
help me please my company is not work
14 Replies 14
Mark Elsen
             >help me please my company is not work ?
 Please elaborate in networking-technical terns what  the problem is (?)
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
the problem I had received new IP address from the ISP and I can't configure my router for new IP
here is the new IP I had received.
Port: sub-interface (1115)
branch IP address : 87.101.135.100
Gateway: 87.101.135.6
DNS: 87.101.202.133
DNS: 87.101.203.9
and I made the configuration as the attached in my post but doesn't
the access list doesn't look right. Change:
to just:
I had change the access list but still WAN doesn't work
the IP address you have received and the subnet mask do not belong to the same subnet as the gateway IP.
Change the IP address to:
ip address 87.101.135.100 255.255.255.0
the subnet from DSP/ISP is like below
branch IP address : 87.101.135.100 /30
Gateway: 87.101.135.6 /30
DNS: 87.101.202.133
DNS: 87.101.203.9
who is your ISP/Provider ? Typically, when they ask you to use a specific subinterface, the corresponding VLAN needs to match.
Try:
encapsulation dot1Q 1115
ip nat outside
till doesn't work I can't ping 8.8.8.8
what is the LED status of interface FastEthernet4 ? Do you have physical connectivity at all ?
In your original configuration, you had Vlan 60 configured, does this Vlan actually exist on your router ? That is, did you manually create it ?
881#conf t
881(config)#vlan 60
luis_cordova
Hi @A7M876
Try this change:
We changed the encapsulation from 60 to 1115
We changed the mask from /30 to /24, because having the mask /30, the configured ip did not belong to the same network.
We simplify the ACL to a single instruction
 ip address 87.101.135.100 255.255.255.255
 ip nat outside
I had changed the mask to /24, with same configuration you had sent to me
but still all users can't access and use (emails, internet,etc)
create Vlan 1115 in the same way, and then use 'encapsulation dot1q 1115' on the subinterface...
did you mean like this
881#vlan 1115
881# encapsulation dot1Q 1115
881# ip address 87.101.135.100 255.255.255.252
 881# ip nat outside
881#  ip virtual-reassembly in
