help configuration for sub interface
A7M876
Visitor
today I received new IP address from the ISP and I really I can't configure my router for new IP
here is the new IP I had received.
Port: sub-interface (1115)
branch IP address : 87.101.135.100
Gateway: 87.101.135.6
DNS: 87.101.202.133
DNS: 87.101.203.9
please help me for configuration for sub-interface and up the network
your configuration is wrong.
The gateway cant be 87.101.135.6/30 and network 87.101.135.100/30 because they are in different network
Network: 87.101.135.100/30           01010111.01100101.10000111.01100100 (Class A)
Broadcast: 87.101.135.103              01010111.01100101.10000111.01100111
HostMin: 87.101.135.101                 01010111.01100101.10000111.01100101
HostMax: 87.101.135.102                01010111.01100101.10000111.01100110
Network: 87.101.135.4/30               01010111.01100101.10000111.000001 00 (Class A)
Broadcast: 87.101.135.7                  01010111.01100101.10000111.000001 11
HostMin: 87.101.135.5                     01010111.01100101.10000111.000001 01
HostMax: 87.101.135.6                    01010111.01100101.10000111.000001 10
your addressing are wrong.. take correctly information with your ISP.
Jaderson Pessoa
*** Rate All Helpful Responses ***
9 Replies 9
balaji.bandi
what router you have, can you post the exiting configuration of the device?
we need to configure this pointing towards ISP side - that can be advise only once we see the exiting information.
BB
thanks for your replay
router model: 881
old router configuration:
ip name-server : 87.101.202.133
ip name-server: 87.101.203.9
interface fastethernet4
ip address: 87.101.135.100 255.255.255.252
ip nat inside
interface Vlan1
ip address: 192.168.1.1 255.255.255.0
ip nat outside
ip route 0.0.0.0 0.0.0.0 87.101.135.6
I do not belive you have provided correct information here : post full show run from device.
and i do not belive below config works.
ip nat inside   - this always should be outside nat
interface Vlan1
ip nat outside  - this should be inside nat since you are using private address space here
interface fastethernet x/x
interface FastEthernet4
no ip address
duplex auto
speed auto
interface FastEthernet4.1
ip address  87.101.135.100 255.255.255.252
ip nat outside
interface FastEthernet4.1115
 ip address  87.101.135.100  mask.x.x.x252
add an additional static router to 87.101.135.6
you can use other interface ip nat outside depends on your requirement.
BB
this router configuration
UCIC_Router#show run
UCIC_Router#show running-config
Building configuration...
Current configuration : 1944 bytes
! Last configuration change at 07:38:22 UTC Thu Nov 14 2019 by ucic
version 15.3
hostname UCIC_Router
boot-start-marker
boot-end-marker
aqm-register-fnf
enable secret 5 $1$Ia.V$8JV7qaB/UWOT/9IXazVD4/
no aaa new-model
ip name-server  87.101.202.133
ip name-server 87.101.203.9
ip cef
no ipv6 cef
license udi pid C881-K9 sn FCZ204613NU
interface FastEthernet0
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
 description " To ITC Modem "
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface Vlan1
 description " Conneted To Switch "
 ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 101 interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0  0.0.0.0 0.0.0.0 87.101.135.6
access-list 101 deny   ip any 192.168.1.0 0.0.0.255
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
end
UCIC_Router#
Jaderson Pessoa
Well... we need more information about your environment to suggest a better solution.
Just suggestive exemple;  As our friends told to you.. we need more information to provide a better suggestion for your environment.
interface gi1/0.1115
ip address 87.101.135.100 255.255.255.128 ( check mask)
dns-servers 87.101.202.133 87.101.203.9
Jaderson Pessoa
still doesn't work
Current configuration : 2013 bytes
ip cef
no ipv6 cef
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 duplex auto
 speed auto
 description " TO ITC Modem "
 encapsulation dot1Q 60
 ip nat outside
interface Vlan1
 ip nat inside
no ip http server
ip nat inside source list 101 interface FastEthernet4.1115 overload
@A7M876  Hello
Please, provide changes below;
no ip route 0.0.0.0 0.0.0.0  0.0.0.0 0.0.0.0 87.101.135.6    ( 87.101.135.6 is out of network range in  87.101.135.100 255.255.255.252 ), maybe is .99 or 101, check it)
ip route 0.0.0.0 0.0.0.0 87.101.135.99 or 101 ( check correctly ip address)
! access-list 101 deny ip any 192.168.1.0 0.0.0.255 << remove this line
no access-list 101 deny ip any 192.168.1.0 0.0.0.255
access-list 101 permit ip 192.168.1.0 0.0.0.255 any !
Jaderson Pessoa
am erase the router but still same issue doesn't work
Jaderson Pessoa
