03-04-2013 11:54 PM - edited 03-07-2019 12:03 PM
I have a Cisco 2811 with 2 fastEthernets. This is configured with:
LAN0 (192.168.0.0/24) <---------> f0/0 (192.168.0.6) --- f0/1 (192.168.1.6) <----------> LAN1 (192.168.1.0/24) <----------> INTERNET
The 2811 can access to Internet. I can ping any host (google.com), and 192.168.0.x, and 192.168.1.x. All is OK.
But i can't ping from 192.168.0.x to 192.168.1.x. LAN1 can't access to LAN2.
This is the configuration
Thanks.
Building configuration...
Current configuration : 1063 bytes
version 12.4
hostname cisco2811
boot-start-marker
boot-end-marker
enable secret 5 $1$KR8N$MNFXgI49lHx9i7hqzi.Fi0
enable password xxxxxxxx
no aaa new-model
resource policy
ip subnet-zero
ip cef
ip name-server 80.58.61.250
ip name-server 80.58.61.254
interface FastEthernet0/0
description $ETH-LAN$
ip address 192.168.0.6 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1
description $ETH-WAN$
ip address 192.168.1.6 255.255.255.0
ip nat outside
duplex auto
speed auto
interface ATM0/0/0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
ip default-gateway 192.168.1.1
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
password xxxxxxx
login
scheduler allocate 20000 1000
end
03-05-2013 01:28 AM
is this the entire config?
Im assuming that fa0 and fa1 are going into seperate switches?
there are no acls configured?
which interface is for internet?
whats the reason for the 2 subnets?
03-05-2013 01:43 AM
Hi, Yasien
Yes, this is te entire config. An this is the graphical configuration:
f0/0 (192.168.0.6)
f0/1 (192.168.1.6)
MODEM/ROUTER (192.168.1.1)
INTERNET
I have 2 subnets because the 192.168.1.x is a subnet with cameras, etc. The default gateway of entire network is a modem/router zyxel with IP 192.168.1.1
Both f0/0 and f0/1 are connected into separate switches.
Thanks.
03-05-2013 01:57 AM
so devices on 0.x can get to the internet ?
devices on 1.x can get to the internet?
03-05-2013 02:04 AM
so devices on 0.x can get to the internet ? => NO INTERNET ACCESS, GATEWAY of devices is 192.168.0.6
devices on 1.x can get to the internet? => YES, because GATEWAY is configured to 192.168.1.1 directly.
03-05-2013 02:56 AM
try
ip routing
OR
int fa0/1
no ip nat outside
ip nat inside
OR
remove NAT from both interfaces
im guessing your modem is already doing NAT
03-05-2013 04:16 AM
None of the three solutions solves the problem
