help with a 4500 log message???
baselzind
Level 6
Level 6
i have a ws-c4500x-16 switch at a customer that is giving this log message:
THRESHOLD_VIOLATION: Te1/1/3: Rx power low warning; Operating value: -21.0 dBm, Threshold value: -19.0 dBm.
please what does it mean? and how do i fix it?
brdewal2
If that port isn't actually connected then you probably have nothing to worry about and might be hitting this bug: https://bst.cloudapps.cisco.com/bugsearch/bug/CSCtk97309
If that port is connected, you likely have a L1 issue of either bad cable or SFP.
Pete Bauer
Aftermarket SFP?
