Help with access lists, separate traffic
firstascent
Hello all,
I've been working on this for awhile now and have tried different configurations but cannot figure out what I'm missing.
It's pretty simple, I think...
I have (1) 1841 router and (1) 2960 24 port switch. Ports 1-12 are on VLAN1 and ports 13-24 are on VLAN5
VLAN1 is on 192.168.1.0 subnet and VLAN5 is on 192.168.10.0 subnet
All I would like to do is keep them separated. I don't want one to see the other and vice versa.
Right now anything on VLAN5 can't ping VLAN1 but... VLAN1 can ping VLAN5. So I'm close, I think, but not quite there yet.
Below is the config from the router. Please let me know if any of you sees something obvious or has any ideas I could try.
Thanks!
Building configuration...
Current configuration : 5204 bytes
version 12.4
service password-encryption
hostname lucee
boot-start-marker
boot system flash:c1841-advsecurityk9-mz.124-25c.bin
boot-end-marker
enable secret 5 $1$ZfZj$Pa/Fh8QWAWCx.eYdkYwsC/
aaa new-model
aaa authentication login userauthen local
aaa authorization network groupauthor local
aaa session-id common
no ip cef
ip auth-proxy max-nodata-conns 10
ip admission max-nodata-conns 10
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.9
ip dhcp excluded-address 192.168.1.31 192.168.1.254
ip dhcp pool gresham
   network 192.168.1.0 255.255.255.0
   dns-server 64.100.100.100 64.100.100.00
   default-router 192.168.1.1
   lease 2
no ip domain lookup
crypto pki trustpoint TP-self-signed-3233092784
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3233092784
revocation-check none
rsakeypair TP-self-signed-3233092784
crypto pki certificate chain TP-self-signed-3233092784
certificate self-signed 01
  3082023D 308201A6 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  D466549E 1EA208B3 829B1915 499E00EE 502BD8A5 A7252C6A C99321AD A2D31E90
  A56DE969 BBD5184F 25FFEC8A 01E68C33 7C3B3682 EAAD3318 65E19EF5 20FBD087 45
  quit
username nameHere password 7 0476
username nameHere privilege 15 password 7 0029
username nameHere privilege 15 password 7 050C
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp nat keepalive 20
crypto isakmp client configuration group groupNameHere
key xxxxx
pool vpnpool
acl 102
crypto isakmp profile ISAKMPprof
   match identity group groupNameHere
   client authentication list userauthen
   isakmp authorization list groupauthor
   client configuration address respond
   virtual-template 3
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec profile IPSecprof
set transform-set ESP-3DES-SHA
set isakmp-profile ISAKMPprof
interface FastEthernet0/0
no ip address
ip virtual-reassembly
duplex auto
speed auto
no keepalive
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address 192.168.1.1 255.255.255.0 secondary
ip address 00.0.000.00 255.255.255.224
ip nat inside
ip tcp adjust-mss 1452
interface FastEthernet0/0.5
encapsulation dot1Q 5
ip address 192.168.10.1 255.255.255.0
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
no keepalive
interface Serial0/0/0
no ip address
encapsulation frame-relay IETF
no ip mroute-cache
service-module t1 timeslots 1-24
service-module t1 fdl both
frame-relay lmi-type ansi
interface Serial0/0/0.1 point-to-point
frame-relay interface-dlci 16 ppp Virtual-Template1
interface Virtual-Template1
ip address negotiated
ip nat outside
ppp chap hostname 558
ppp chap password 7 115A4C
ppp ipcp dns request
ppp ipcp route default
ppp ipcp address accept
interface Virtual-Template3 type tunnel
ip unnumbered FastEthernet0/0.1
tunnel mode ipsec ipv4
tunnel protection ipsec profile IPSecprof
ip local pool vpnpool 172.16.1.1 172.16.1.10
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
ip nat pool nat 00.0.000.00 00.0.000.00 netmask 255.255.255.224
ip nat inside source list 105 pool nat overload
access-list 102 permit ip 192.168.10.0 0.0.0.255 any
access-list 102 permit ip 192.168.1.0 0.0.0.255 any
access-list 105 deny   ip 192.168.1.0 0.0.0.255 172.16.0.0 0.0.255.255
access-list 105 deny   ip 192.168.10.0 0.0.0.255 172.16.0.0 0.0.255.255
access-list 105 permit ip 192.168.1.0 0.0.0.255 any
control-plane
line con 0
line aux 0
line vty 0 4
password 7 12340
logging synchronous
transport input telnet ssh
scheduler allocate 20000 1000
end
2 Accepted Solutions
Vlan 1 - 192.168.1.1 255.255.255.0
Vlan 5 - 192.168.10.1 255.255.255.0
Separate traffic via ACL
access-list 111 deny ip 192.168.1.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 111 permit ip 192.168.1.0 0.0.0.255 any
access-list 112  deny ip 192.168.10.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 112 permit ip 192.168.10.0 0.0.0.255 any
interfaceFa0/0.1
ip access-group 111 in
int Fa0/0.5
ip access-group 112 in
That should do it.
Note: You seem to have two ranges on Fa0/0.1 (looks like you masked the primary ip).  I would've added the primary to the ACL config, but I don't know what it is so I excluded it.  But for practicality, it looks like this as is:
access-list 111 deny ip 0.0.0.0 0.0.0.31 192.168.10.0 0.0.0.255  <-----Replace 0.0.0.0 0.0.0.31 with your fa0/0.1 primary range
access-list 112  deny ip 192.168.10.0 0.0.0.255 0.0.0.0 0.0.0.31  <-----Replace 0.0.0.0 0.0.0.31 with your fa0/0.1 primary range
Message was edited by: Antonio Knox
I'll assume you're using the server address 192.168.1.1 (Fa0/0.1)
You will need to allow DHCP requests (UDP 68) to the DHCP server.
Add this to your 111 ACL
Start from scratch(-ish)
no access-list 111  deny ip 192.168.1.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 111 permit any host 192.168.1.1 eq bootps
no access-list 111 permit ip 192.168.1.0 0.0.0.255 any
I did it this way so that the order of the access list is maintained.  After all the hubub, it will look like this:
access-list 111 permit any host 192.168.1.1 eq bootps  <----Allow DHCP requests to 192.168.1.1
Corrected for your convenience
22 Replies 22
Hi Jaime,
did you already try it via ACL? and add them to the vlan interfaces? could work I think...
example:
access-list 111 deny   ip 192.168.1.0 0.0.0.255 192.168.10.0 0.0.255.255
access-list 112 deny   ip 192.168.10.0 0.0.0.255 192.168.1.0 0.0.255.255
regards,
Sebastian
On the switch? I haven't tried it on the switch yet if that is what you are referring too.
If you meant the router, I've tried it on the router as you can see at the end of my config, but it doesn't look like what you posted so I could try that.
Let me know if you meant the router or the switch.
Thank You.
Sorry I mean on the router
To apply it to the interface I just use
correct?
I tried applying one to fa0/0.5 and then I couldn't ping 192.168.10.100, which is good. I took it off and then I could ping it again.
But, then I applied 112 instead of 111 to the same interface and it did the same thing.
Why would it do that? I think we/you are on the right track because I haven't gotten it to do that yet until now which is good.
If you use just "in" which is enough I would say I would prefer 111 to fas 0/0.5 and 112 to fas 0/0.1
The ACL is source / destination and "in" = destination. OK?
to use 112 on fas0/0.5 gives the same result because I did a mistake try this pls.
my last post was:
Sorry for that..
pls. don't forgett to rate if it is solved...
regards
sebastian
I updated it to
however, 111 and 112 both still worked on fa0/0.5
When I applied 112 to fa0/0.1 then I lost access to everthing and had to restart the router.
Yepp sorr i forgott on ever acl end is a eypliciet deny any i forgott maybe you need to add an permit...
Gesendet von meinem Windows Phone
interfaceFa0/0.1
int Fa0/0.5
That should do it.
that seems to be working for now with adding the 'permit'
can you expain the acl a little for me. I thought I understood it but now I'm a little confused.
When i look at it, acl 111 for example, it looks like we are denying AND permitting 192.168.1.0 0.0.0.255??
An ACL works from top down.  Once it finds a match, it stops processing right there and either permits or denies traffic depending on the matching rule.  In this case traffic from one vlan to the other hits the first line of the ACL and sees a deny because there is a match in source and destination address.  It stops right there, so the ACL never processes that traffic past the first line.  If either vlan was going somewhere other than the opposite vlan, it would not match the first line, and would be permitted by the second line.
Make sense?
Please rate helpful posts.
Thanks, yes that makes sense, on ACL 111 it is saying
do not allow traffic from 192.168.1.0 to go to 192.168.10.0
do allow traffic from 192.168.1.0 to anywhere else
because the first portion is the "source' and the second portion is the "destination"
correct? I think I'm understanding it more now.
so when applying the ACL to the interface what would happen if I changed it to "out" instead of "in". I'm a little unclear on that part.
You are correct.
Think of an interface as 'facing' the ip address space that it serves.
Fa0/0.1 --------is facing-------- LAN
when applying an ACL inbound, the LAN goes to the interface, but from the interface's perspective the traffic is filtered as it is coming in.
Fa0/0.1  <-----sees/filers traffic coming in from---------  LAN
when applying an ACL outbound, from the interface's perspective the traffic is filtered as it goes out from the interface to the LAN
Fa0/0.1 --------sees/filters traffic going out to -------->  LAN
Make sense?
wasn't sure if I should start a new post but this is related to all the above I have been doing.
as you can see from the config I have DHCP setup on the router. Except now with the applied ACL's dhcp isn't working.
Is there something I need to add for dhcp as well? I just have an Access Point connected to vlan 1 on the switch with is going to fa0/0.1
so there may be something I need to add to ACL 111.....?
What is your DHCP server address?
