Help with access lists, separate traffic
firstascent
Hello all,
I've been working on this for awhile now and have tried different configurations but cannot figure out what I'm missing.
It's pretty simple, I think...
I have (1) 1841 router and (1) 2960 24 port switch. Ports 1-12 are on VLAN1 and ports 13-24 are on VLAN5
VLAN1 is on 192.168.1.0 subnet and VLAN5 is on 192.168.10.0 subnet
All I would like to do is keep them separated. I don't want one to see the other and vice versa.
Right now anything on VLAN5 can't ping VLAN1 but... VLAN1 can ping VLAN5. So I'm close, I think, but not quite there yet.
Below is the config from the router. Please let me know if any of you sees something obvious or has any ideas I could try.
Thanks!
Building configuration...
Current configuration : 5204 bytes
version 12.4
service password-encryption
hostname lucee
boot-start-marker
boot system flash:c1841-advsecurityk9-mz.124-25c.bin
boot-end-marker
enable secret 5 $1$ZfZj$Pa/Fh8QWAWCx.eYdkYwsC/
aaa new-model
aaa authentication login userauthen local
aaa authorization network groupauthor local
aaa session-id common
no ip cef
ip auth-proxy max-nodata-conns 10
ip admission max-nodata-conns 10
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.9
ip dhcp excluded-address 192.168.1.31 192.168.1.254
ip dhcp pool gresham
   network 192.168.1.0 255.255.255.0
   dns-server 64.100.100.100 64.100.100.00
   default-router 192.168.1.1
   lease 2
no ip domain lookup
crypto pki trustpoint TP-self-signed-3233092784
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3233092784
revocation-check none
rsakeypair TP-self-signed-3233092784
crypto pki certificate chain TP-self-signed-3233092784
certificate self-signed 01
  3082023D 308201A6 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  D466549E 1EA208B3 829B1915 499E00EE 502BD8A5 A7252C6A C99321AD A2D31E90
  A56DE969 BBD5184F 25FFEC8A 01E68C33 7C3B3682 EAAD3318 65E19EF5 20FBD087 45
  quit
username nameHere password 7 0476
username nameHere privilege 15 password 7 0029
username nameHere privilege 15 password 7 050C
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp nat keepalive 20
crypto isakmp client configuration group groupNameHere
key xxxxx
pool vpnpool
acl 102
crypto isakmp profile ISAKMPprof
   match identity group groupNameHere
   client authentication list userauthen
   isakmp authorization list groupauthor
   client configuration address respond
   virtual-template 3
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec profile IPSecprof
set transform-set ESP-3DES-SHA
set isakmp-profile ISAKMPprof
interface FastEthernet0/0
no ip address
ip virtual-reassembly
duplex auto
speed auto
no keepalive
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address 192.168.1.1 255.255.255.0 secondary
ip address 00.0.000.00 255.255.255.224
ip nat inside
ip tcp adjust-mss 1452
interface FastEthernet0/0.5
encapsulation dot1Q 5
ip address 192.168.10.1 255.255.255.0
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
no keepalive
interface Serial0/0/0
no ip address
encapsulation frame-relay IETF
no ip mroute-cache
service-module t1 timeslots 1-24
service-module t1 fdl both
frame-relay lmi-type ansi
interface Serial0/0/0.1 point-to-point
frame-relay interface-dlci 16 ppp Virtual-Template1
interface Virtual-Template1
ip address negotiated
ip nat outside
ppp chap hostname 558
ppp chap password 7 115A4C
ppp ipcp dns request
ppp ipcp route default
ppp ipcp address accept
interface Virtual-Template3 type tunnel
ip unnumbered FastEthernet0/0.1
tunnel mode ipsec ipv4
tunnel protection ipsec profile IPSecprof
ip local pool vpnpool 172.16.1.1 172.16.1.10
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
ip nat pool nat 00.0.000.00 00.0.000.00 netmask 255.255.255.224
ip nat inside source list 105 pool nat overload
access-list 102 permit ip 192.168.10.0 0.0.0.255 any
access-list 102 permit ip 192.168.1.0 0.0.0.255 any
access-list 105 deny   ip 192.168.1.0 0.0.0.255 172.16.0.0 0.0.255.255
access-list 105 deny   ip 192.168.10.0 0.0.0.255 172.16.0.0 0.0.255.255
access-list 105 permit ip 192.168.1.0 0.0.0.255 any
control-plane
line con 0
line aux 0
line vty 0 4
password 7 12340
logging synchronous
transport input telnet ssh
scheduler allocate 20000 1000
end
22 Replies 22
I don't have a separate DHCP server, I'm just using the router to assign a dhcp address
I'll assume you're using the server address 192.168.1.1 (Fa0/0.1)
You will need to allow DHCP requests (UDP 68) to the DHCP server.
Add this to your 111 ACL
Start from scratch(-ish)
no access-list 111  deny ip 192.168.1.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 111 permit any host 192.168.1.1 eq bootps
no access-list 111 permit ip 192.168.1.0 0.0.0.255 any
I did it this way so that the order of the access list is maintained.  After all the hubub, it will look like this:
access-list 111 permit any host 192.168.1.1 eq bootps  <----Allow DHCP requests to 192.168.1.1
Corrected for your convenience
Message was edited by: Antonio Knox
firstascent
do I need to have
access-list 112 permit ip any host 192.168.1.1 eq bootps
instead of
access-list 112 permit any host 192.168.1.1 eq bootps
the router didn't take the one you suggested.
the pc's that need dhcp go through fa0/0.1 so wouldn't I want to put that on acl 111 not acl 112?
Correct on both counts.  *ip* was omitted by mistake, I type from the brain, so I miss characters from time to time.
If the host that require DHCP are on Fa0/0.1, apply it to 111.  I went on an assumption since Fa0/0.5 was the network explicitly blocked.
I'm not my sharpest today.  Good catch.
See the updated config above.
ok, getting closer
so when i have the 192.168.1.1 ip address in there it works intermittently. I also tried using the primary address of the router and it also works intermittently.
i can connect, then lose the ip address, then about a minute later it will get the ip address back.
If I change the line to
access-list 111 permit udp any any eq bootps
then it works quickly and keep the ip address as it should.
But I would think that leaving it "any any" leaves it open for some vulnerability?
Thanks, I'm so close.
For functionality, this is a good spot to be in.  I don't think that you will have issues with security here, so I would say you're good.  I think what happens is the DHCP request is sent to a broadcast address (since no helper is defined) and locking the ACL down to a single ip with no helper address (since it shouldn't be necessary here) may be a problem, especially seeing that no one wants to allow bootps to a broadcast address.  Leave it as is and you should be good.
Don't forget to rate for good help, my friend.
thank you so much! this little issue has been a headache the last few months, I knew it was a simple fix too!
But it's always the little stuff that gives us the most grief, right?   Happy to be of help to you.
