help with cisco 887va and vodafone
skyjames83
hi all
please forgive my ignorance , i am very very new to cisco and i know nothing about it at all . The reason for this post is would like to use a cisco 887va to replace my vodafone crappy little hub with i use for my house  , i the reason i want to use the cisco is i was given it brand new and was told it was a much better product and wont let me down . After reading many web pages and artivles i know i have made the right choice .does anyone have a working config that works so i have NAT ? i also have a cisco linksys switch which runs all my house like xbox one , ps4 , laptops and other equipment that uses ethernet
many thanks for reading this and greatly accept any info
regards
22 Replies 22
the configuration provided would work with option 1. Just connect the Linksys to one of the LAN ports on the 887VA. All your devices will automatically get IP addresses in the 192.168.1.0/24 addres range.
me again last ?
do i need to update/upgraded firware on the 887 if so were can i get it from because i have registered and i cant get access to the downloads section as i am not a cisco parnter just a memeber of the general public
you don't need to upgrade the firmware (ROMMON Monitor image), the last release is from 2010 anyway.
The configuration posted will work just fine.
Let us know when you need more assistance...
hi there
thanks for this config but is it for vodafone fibre ?
plus how does this look
Cisco Virtual Office (CVO) is installed on this device and it provides the
default username "cisco".
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username <myuser> privilege 15 secret 0 <mypassword>
Replace <myuser> and <mypassword> with the username and password you want to
use.
For more information about CVO please go to http://www.cisco.com/go/cvo
^C
line con 0
exec-timeout 5 30
login
no modem enable
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login
transport input all
HOME#conf t
Enter configuration commands, one per line. End with CNTL/Z.
HOME(config)#Home username privilege 15 sercet 0 admin
% Invalid input detected at '^' marker.
HOME(config)#username Home privilege 15 secret 0
% Incomplete command.
HOME(config)#^Z
HOME#
*Sep 13 19:58:49.406: %SYS-5-CONFIG_I: Configured from console by console
HOME#setup
--- System Configuration Dialog ---
Continue with configuration dialog? [yes/no]: y
At any point you may enter a question mark '?' for help.
Use ctrl-c to abort configuration dialog at any prompt.
Default settings are in square brackets '[]'.
Basic management setup configures only enough connectivity
for management of the system, extended setup will ask you
to configure each interface on the system
Would you like to enter basic management setup? [yes/no]: yes
Configuring global parameters:
Enter host name [HOME]: home
The enable secret is a password used to protect access to
privileged EXEC and configuration modes. This password, after
entered, becomes encrypted in the configuration.
Enter enable secret [<Use current secret>]: admin
The enable password is used when you do not specify an
enable secret password, with some older software versions, and
some boot images.
Enter enable password: admin
% Please choose a password that is different from the enable secret
Enter enable password: cisco
The virtual terminal password is used to protect
access to the router over a network interface.
Enter virtual terminal password: cisco
Configure SNMP Network Management? [no]: no
Current interface summary
ATM0 unassigned YES unset administratively down down
ATM0.1 unassigned YES unset administratively down down
Dialer0 unassigned YES manual up up
Ethernet0 unassigned YES unset administratively down down
FastEthernet0 unassigned YES unset up up
FastEthernet1 unassigned YES unset down down
FastEthernet2 unassigned YES unset down down
FastEthernet3 unassigned YES unset down down
Loopback0 unassigned YES unset up up
NVI0 unassigned YES unset up up
Virtual-Access1 unassigned YES unset up up
Vlan1 192.168.1.1 YES manual up up
Enter interface name used to connect to the
management network from the above interface summary: yes
Invalid interface
management network from the above interface summary: fastethernet 0
Invalid interface
Invalid interface
Configuration aborted, no changes made.
HOME#show run
Building configuration...
Current configuration : 7333 bytes
! Last configuration change at 19:58:49 UTC Wed Sep 13 2017
version 15.6
hostname HOME
boot-start-marker
boot config usbflash0:CVO-BOOT.CFG
boot-end-marker
logging buffered 51200 warnings
enable secret 5 $1$50FA$/7CGtU89kWLuPrQQddn6C.
no aaa new-model
ethernet lmi ce
crypto pki trustpoint TP-self-signed-4291880973
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-4291880973
revocation-check none
rsakeypair TP-self-signed-4291880973
crypto pki certificate chain TP-self-signed-4291880973
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 34323931 38383039 3733301E 170D3137 30393133 31393039
35315A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D34 32393138
38303937 3330819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100B2D0 8D92CE84 F08AB819 47C2F618 8303A15A D544FCD2 ECC1F023 AD354912
018868FF 69D7818F 1EC4D1E3 0FEF11FC 514E64F9 D94C618C F1A56C23 F24FE8B7
7FFC8DE6 08757D36 C0D0F9BB DF2AF32A 6735F260 ABAF8CD6 665425A0 478C3A6F
0000799F 73D88838 9DC18216 4E0207C2 2E8AE00E 56770921 882FF804 1BC428A4
603D0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 146EC9DA 56506BA0 83867171 1B662862 7313F401 73301D06
03551D0E 04160414 6EC9DA56 506BA083 8671711B 66286273 13F40173 300D0609
2A864886 F70D0101 05050003 81810057 61CAB4A3 C9F85A5C ADB071B2 EF875FA7
8AB1255D CD164399 9E4E8556 30BA5D61 C2620C00 EA175342 B46BC3FD ADC60D46
9662C04D 08E97FDF 0D84C009 A1B7FC51 57C94E85 54E1E8EC 228E3E9A 3859236D
52AA93BA B3811D72 3290BD2F 2F046875 7EC3E06A C7B9DE22 C6F9089D 8C005137
D426B4C4 69B1CF39 3F9BA14D 95D97C
quit
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 192.168.1.1
ip dhcp pool cvo-pool
import all
network 10.10.10.0 255.255.255.248
default-router 10.10.10.1
lease 0 2
ip dhcp pool VLAN1
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8 8.8.4.4
no ip domain lookup
ip domain name yourdomain.com
ip inspect name DEFAULT100 ftp
ip inspect name DEFAULT100 h323
ip inspect name DEFAULT100 icmp
ip inspect name DEFAULT100 netshow
ip inspect name DEFAULT100 rcmd
ip inspect name DEFAULT100 realaudio
ip inspect name DEFAULT100 rtsp
ip inspect name DEFAULT100 esmtp
ip inspect name DEFAULT100 sqlnet
ip inspect name DEFAULT100 streamworks
ip inspect name DEFAULT100 tftp
ip inspect name DEFAULT100 tcp
ip inspect name DEFAULT100 udp
ip inspect name DEFAULT100 vdolive
ip cef
no ipv6 cef
vpdn enable
vpdn-group 1
vpdn-group REMOTE-VPN
! Default PPTP VPDN group
description Default PPTP VPDN group
accept-dialin
protocol pptp
virtual-template 1
license udi pid C887VA-K9 sn FCZ2049102X
username cisco privilege 15 secret 5 $1$71bC$jqMnKLD7YLrW.Z0GCaatb/
controller VDSL 0
no cdp run
interface Loopback0
no ip address
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
shutdown
no atm ilmi-keepalive
interface ATM0.1 point-to-point
pvc 8/35
pppoe-client dial-pool-number 1
interface Ethernet0
description $WAN_OUTSIDE$
no ip address
no ip route-cache
shutdown
pppoe enable group global
interface FastEthernet0
no ip address
no cdp enable
spanning-tree portfast
interface FastEthernet1
no ip address
no cdp enable
interface FastEthernet2
no ip address
no cdp enable
interface FastEthernet3
no ip address
no cdp enable
interface Vlan1
description Internal LAN
ip access-group 100 in
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1452
interface Dialer0
description ADSL WAN
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxxxxxxx@vodafone.com
ppp chap password 0 broadband
ppp pap sent-username xxxxxxxxx@vodafone.com password 0 broadband
no cdp enable
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
no ip ftp passive
ip nat inside source list 1 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
no service-routing capabilities-manager
dialer-list 1 protocol ip permit
access-list 1 permit 10.10.10.0 0.0.0.7
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 permit udp any eq bootps any eq bootpc
access-list 101 deny ip 10.10.10.0 0.0.0.255 any
access-list 101 permit icmp any any echo-reply
access-list 101 permit icmp any any time-exceeded
access-list 101 permit icmp any any unreachable
access-list 101 deny ip 10.0.0.0 0.255.255.255 any
access-list 101 deny ip 172.16.0.0 0.15.255.255 any
access-list 101 deny ip 192.168.0.0 0.0.255.255 any
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 deny ip host 255.255.255.255 any
access-list 101 deny ip any any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
banner exec ^C
% Password expiration warning.
use.
^C
banner login ^C
use.
^C
line con 0
exec-timeout 5 30
login
no modem enable
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login
transport input all
scheduler allocate 20000 1000
end
HOME#conf t
HOME(config)#no ip domain lookup
HOME(config)#ip cef
HOME(config)#no ipv6 cef
HOME(config)#!
HOME(config)#ip dhcp excluded-address 192.168.1.1
HOME(config)#!
HOME(config)#ip dhcp pool VLAN1
HOME(dhcp-config)#import all
HOME(dhcp-config)#network 192.168.1.0 255.255.255.0
HOME(dhcp-config)#default-router 192.168.1.1
HOME(dhcp-config)#dns-server 8.8.8.8 8.8.4.4
HOME(dhcp-config)#!
HOME(dhcp-config)#multilink bundle-name authenticated
HOME(config)#vpdn enable
HOME(config)#!
HOME(config)#vpdn-group 1
HOME(config-vpdn)#!
HOME(config-vpdn)#vpdn-group REMOTE-VPN
HOME(config-vpdn)#! Default PPTP VPDN group
HOME(config-vpdn)#description Default PPTP VPDN group
HOME(config-vpdn)#accept-dialin
HOME(config-vpdn-acc-in)#protocol pptp
HOME(config-vpdn-acc-in)#virtual-template 1
HOME(config-vpdn-acc-in)#!
HOME(config-vpdn-acc-in)#license udi pid CISCO887VA-SEC-K9 sn FCZ172390QW
Warning: The input license udi(CISCO887VA-SEC-K9:FCZ172390QW) differs from the platform udi(C887VA-K9:FCZ2049102X).
HOME(config)#!
HOME(config)#controller VDSL 0
HOME(config-controller)#!
HOME(config-controller)#no ip ftp passive
HOME(config)#!
HOME(config)#interface Loopback0
HOME(config-if)#no ip address
HOME(config-if)#!
HOME(config-if)#interface Ethernet0
HOME(config-if)#description $WAN_OUTSIDE$
HOME(config-if)#no ip route-cache
HOME(config-if)#shutdown
HOME(config-if)#pppoe enable
HOME(config-if)#pppoe-client dial-pool-number 1
HOME(config-if)#!
HOME(config-if)#interface ATM0
HOME(config-if)#no ip redirects
HOME(config-if)#no ip unreachables
HOME(config-if)#no ip proxy-arp
HOME(config-if)#ip flow ingress
HOME(config-if)#bundle-enable
HOME(config-if)#no atm ilmi-keepalive
HOME(config-if)#dsl operating-mode auto
HOME(config-if)#!
HOME(config-if)#interface ATM0.1 point-to-point
HOME(config-subif)#no ip address
HOME(config-subif)#no ip directed-broadcast
HOME(config-subif)#no atm ilmi-keepalive
HOME(config-subif)#pvc 8/35
HOME(config-if-atm-vc)#pppoe-client dial-pool-number 1
HOME(config-if-atm-vc)#!
HOME(config-if-atm-vc)#interface FastEthernet0
HOME(config-if)#no cdp enable
HOME(config-if)#!
HOME(config-if)#interface FastEthernet1
HOME(config-if)#!
HOME(config-if)#interface FastEthernet2
HOME(config-if)#!
HOME(config-if)#interface FastEthernet3
HOME(config-if)#!
HOME(config-if)#interface Vlan1
HOME(config-if)#description Internal LAN
HOME(config-if)#ip address 192.168.1.1 255.255.255.0
HOME(config-if)#ip nat inside
HOME(config-if)#ip virtual-reassembly in
HOME(config-if)#!
HOME(config-if)#interface Dialer0
HOME(config-if)#description ADSL WAN
HOME(config-if)#ip address negotiated
HOME(config-if)#ip mtu 1492
HOME(config-if)#ip nat outside
HOME(config-if)#encapsulation ppp
HOME(config-if)#dialer pool 1
HOME(config-if)#dialer-group 1
HOME(config-if)#ppp authentication chap pap callin
HOME(config-if)#ppp chap hostname username@vodafone.com
HOME(config-if)#ppp chap password 0 broadband
HOME(config-if)#$t-usernsent-username password@vodafone.com password 0 broadb
*Sep 13 20:04:40.218: %PARSE_RC-4-PRC_NON_COMPLIANCE: `pppoe-client dial-pool-number 1'ame password@vodafone.com password 0 broadband
HOME(config-if)#!
HOME(config-if)#ip forward-protocol nd
HOME(config)#ip http server
HOME(config)#ip http authentication local
HOME(config)#ip http secure-server
HOME(config)#!
HOME(config)#ip nat inside source list 1 interface Dialer0 overload
HOME(config)#!
HOME(config)#ip route 0.0.0.0 0.0.0.0 Dialer0
HOME(config)#!
HOME(config)#no service-routing capabilities-manager
HOME(config)#dialer-list 1 protocol ip permit
HOME(config)#!
HOME(config)#no cdp run
HOME(config)#!
HOME(config)#access-list 1 permit 192.168.1.0 0.0.0.255
HOME(config)#!
HOME(config)#control-plane
HOME(config-cp)#line con 0
HOME(config-line)#exec-timeout 5 30
HOME(config-line)#password ?
0 Specifies an UNENCRYPTED password will follow
7 Specifies a HIDDEN password will follow
LINE The UNENCRYPTED (cleartext) line password
HOME(config-line)#login
% Login disabled on line 0, until 'password' is set
HOME(config-line)#no modem enable
HOME(config-line)#line aux 0
HOME(config-line)#line vty 0 4
% Login disabled on line 10, until 'password' is set
% Login disabled on line 11, until 'password' is set
% Login disabled on line 12, until 'password' is set
% Login disabled on line 13, until 'password' is set
% Login disabled on line 14, until 'password' is set
HOME(config-line)#transport input all
HOME(config-line)#!
HOME(config-line)#end
HOME#
*Sep 13 20:05:05.314: %SYS-5-CONFIG_I: Configured from console by console
HOME#conf t
HOME(config)#line vty 0 4
HOME(config-line)#password cisco
HOME(config-line)#^Z
HOME#
*Sep 13 20:07:55.437: %SYS-5-CONFIG_I: Configured from console by consoleconf t
HOME#
*Sep 13 20:08:18.424: %SYS-5-CONFIG_I: Configured from console by consoleshow config
Using 4862 out of 262136 bytes!
! The default startup configuration file for Cisco Virtual Office (CVO)
! DO NOT modify this file; it is required by CVO for factory defaults
! Version 1.2
hostname yourname
logging message-counter syslog
username cisco privilege 15 secret 0 cisco
import all
lease 0 2
no ip domain lookup
no ip address
no shutdown
no ip address
no shutdown
no ip address
no shutdown
no ip address
no shutdown
interface FastEthernet4
description $ES_WAN$$FW_OUTSIDE$
no ip dhcp client request tftp-server-address
ip address dhcp
ip access-group 101 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip inspect DEFAULT100 out
ip route-cache flow
duplex auto
speed auto
no shutdown
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$CVO$
ip address 10.10.10.1 255.255.255.248
ip nat inside
ip http server
ip nat inside source list 1 interface FastEthernet4 overload
banner exec ^
use.
banner login ^
use.
no cdp run
line con 0
login local
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet
transport input telnet ssh
event manager applet tti-gen
event timer countdown time 1
action 1.0 cli command "en"
action 2.2 cli command "conf t" pattern "conf"
action 2.3 cli command "crypto key generate rsa general modulus 1024 label tti" pattern "conf"
action 2.4 cli command "no event manager applet tti-gen" pattern "conf"
end
HOME#confog
Translating "confog"
% Bad IP address or host name
% Unknown command or computer name, or unable to find computer address
HOME#config
Configuring from terminal, memory, or network [terminal]?
HOME(config)# Login disabled on line 10, until 'password' is set
HOME(config)#ip cef
HOME(config)#!
HOME(config)#!
HOME(dhcp-config)#!
HOME(config)#!
HOME(config-vpdn)#!
HOME(config)#!
HOME(config)#!
HOME(config-if)#!
HOME(config-if)#!
HOME(config-if)#!
HOME(config-if)#!
HOME(config-if)#!
HOME(config-if)#!
HOME(config-if)#!
HOME(config-if)#!
*Sep 13 20:09:32.904: %PARSE_RC-4-PRC_NON_COMPLIANCE: `pppoe-client dial-pool-number 1'ame password@vodafone.com password 0 broadband
HOME(config-if)#!
HOME(config)#!
HOME(config)#!
HOME(config)#!
HOME(config)#!
HOME(config)#!
HOME(config)#!
Do you have a connection to the Internet with this configuration ?
yeah , will i have to setup a firewall as i already have them on my laptop and PCs . will this act as a normal router now or do i need to do anything else
i am very very new to this
if you have Internet connectivity, you don't need to configure anything else.
will this config work on the vodafone fibre broandband , and this router with the current config will work as it should now
thanks
