Help with DHCP - Apipa being used
Repsak008
Hi everyone,
I am having trouble with an assignment my instructor have given me.
In this assignment i have to configure different things: VLAN, Inter-VLAN routing, OSPF, NAT etc.
Right now i have setup VLANs, trunks, etherchannels, RSTP, Portfast & BPDU, port-security, Inter-VLAN, HSRP and OSPF - it is very certain that i have probably configured something wrong..
But right now i am trying to configure DHCPv4 and PC2 and PC4 needs to receive their IP-addresses from DHCP.
I have configured router GW-R2 with the following:
GW-R2(config)#ip dhcp excluded-address 201.10.2.1 201.10.2.3
GW-R2(config)#ip dhcp pool GUEST
GW-R2(dhcp-config)#network 201.10.2.0 255.255.255.0
GW-R2(dhcp-config)#dns-server 201.10.10.10
GW-R2(dhcp-config)#default-router 201.10.2.1
GW-R2(dhcp-config)#domain-name H2aflevering.net
And router HQ-R3 and HQ-R4 with the following:
HQ-R3(config)#interface gi0/0/1.20
HQ-R3(config-subif)#ip helper-address 201.10.23.1
HQ-R4(config)#interface gi0/0/1.20
HQ-R4(config-subif)#ip helper-address 201.10.23.1
But it is not working. I am novice with this kind of work and i was hoping someone could find the time to take a look at my work so far. I have uploaded my packet tracer file and the layer 2 and layer 3 drawing i have received from my instructor.
It should. I also attached the file and it is working for me here. Take a look and compare the config.
Basically it work with adding the additional route on the OSPF, adding the ip helper-address on the interface and creating a new DHCP scope for Office.
Anything else seems to be ok.
6 Replies 6
Repsak008
I forgot to mention that my instructor made an error in his drawings of the network:
201.10.10.0/30 - It is supposed to be /24
201.10.23.0/30 - It is supposed to be /24
201.10.24.0/30 - It is supposed to be /24
  On the  HQ-R3 you forgot to add one route on the OSPF.
router ospf 10
router-id 2.2.2.2
log-adjacency-changes
network 201.10.23.0 0.0.0.255 area 0
network 201.10.1.0 0.0.0.255 area 0
network 201.10.34.0 0.0.0.3 area 0
network 201.10.2.0 0.0.0.255 area 0
And, for Vlan 10, you forgot the ip helper-address on the interface
interface GigabitEthernet0/0/1.10
description SUB-VLAN10
encapsulation dot1Q 10
ip address 201.10.1.2 255.255.255.0
ipv6 address FE80::3 link-local
ipv6 address 2001:DB8:55:1::2/64
standby version 2
standby 1 ip 201.10.1.1
standby 1 priority 150
standby 1 preempt
standby 2 ipv6 autoconfig
standby 2 priority 150
standby 2 preempt
and you need to create on more DHCP scopo on the Router
ip dhcp excluded-address 201.10.1.1 201.10.1.3
ip dhcp pool OFFICE
network 201.10.1.0 255.255.255.0
default-router 201.10.1.1
Hi Flavio,
Thank you for your reply - and your help It is appreciated.
I corrected my configuration with your instructions but i unfortunately still cannot get PC2 and PC4 to get an IP address from DHCP.
Thanks again Flavio I really am a novice.. I used part of your configuration on the wrong interface.... My bad.
I really appreciate your help and especially your explanation - i get what i was doing wrong now
I hope you have a nice weekend!
@Repsak008
 Great. Glad you find out. Go for it, you are on the right path. This topology was not simple and you did most of the job right. Congrats
 Have a lovely weekand yourself
