Help with dhcp forwarder
boe boe
Community Member
Hello all,
I want to set up a dhcp-relay.
There are 2 routers one is the dhcp server the other one is the forwarder.
Please see the attached file (from Cisco packet tracer).
The pc on the right side only give my a message with a failure of retrieving a ip address.
What am I doing wrong??
Thanks in advanced!
on R2:
enable
conf t
ip route 10.1.11.0 255.255.255.0 10.1.10.1
Alain
8 Replies 8
John Blakley
A lot of us don't use packet tracer. Can you post the configs instead?
Basically, without seeing the config, you will have R1 as dhcp server and R2 as a forwarder. The helper address will be configured on the lan side toward the pc, and you'll have to have routes between R1 and R2:
R1 --- R2 --- PC
R1:
ip dhcp pool Test
network 192.168.12.0
default-router 192.168.12.1
R1 connection to R2 - 10.10.10.1
R2 connection to R1 - 10.10.10.2
R2 Lan address - 192.168.12.1
R2 fa0/1
ip addre 192.168.12.1
ip helper-addre 10.10.10.1
There are a few bugs in packet tracer too, so posting the configs will allow us to see if there's a problem. When the pc broadcasts for a dhcp server, the lan interface on R2 will see it and package it up as a unicast and send it to R1. R1 will see the requesting subnet and assign an address from the 192.168.12.0 pool.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
cadet alain
You must have a route for the gia address( which is the ip address where your helper-address is set) on the DHCP server(which is router2). This is because the DHCP replies are unicasted to this IP and then relayed as unicast or broadcast to the DHCP client.
Regards.
Alain
Ok here we go,
Pc is dhcp not static
Forwarder (I removed some of the "!" there were a lot of them 😞
Building configuration...
Current configuration : 473 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
interface FastEthernet0/0
ip address 10.1.10.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.1.11.1 255.255.255.0
ip helper-address 10.1.10.2
duplex auto
speed auto
ip classless
line con 0
line aux 0
line vty 0 4
login
end
DHCP router:
Current configuration : 566 bytes
version 12.2
hostname Router
ip dhcp excluded-address 10.1.11.1
ip dhcp pool hallo
network 10.1.11.0 255.255.255.0
default-router 10.1.11.1
dns-server 4.4.4.4
ip address 10.1.10.2 255.255.255.0
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
ip classless
line con 0
line aux 0
line vty 0 4
login
end
So makes this it a little bit more clear??
look at my reply, without this routing info R2 will never reply to DHCP requests from the client as it doesn't know how to send them.
Alain
i read it, but don't get it.
How do I make that route?
on R2:
enable
conf t
Alain
Thanks man that was the answer I was looking for!!
Pop in the route to the subnet so that it knows what to send them down
