Help with error on 4507R with Sup V
branfarm1
Level 4
Level 4
Hi, I've been seeing these errors in the log of one of my 4507R switches and I need some help trying to interpret it:
Jun 18 13:32:03: %C4K_PKTPROCESSING-4-ERRORPACKET: Warning - Unexpected packet hitting output acl
pdd = 0x98000208, 0x80000076
118 bytes: 00 1C F6 DE 38 C0 00 19 BB 34 22 D6 08 00 45 00
00 64 71 A9 00 00 80 01 B2 F4 0A 0A 00 F5 0A 0A
00 F3 08 00 45 8E 00 08 C4 03 53 6F 6
Jun 18 13:32:03: %C4K_HWACLMAN-4-WARNINGSTRING: Output Acl HW Cam Stats
Jun 18 13:32:03: %C4K_HWACLMAN-4-WARNINGSTRING: Entry: 0 PacketCount: 8531106
Jun 18 13:32:03: %C4K_HWACLMAN-4-WARNINGSTRING: Entry: 2 PacketCount: 677
Jun 18 13:32:03: %C4K_HWACLMAN-4-WARNINGSTRING: Entry: 17 PacketCount: 7555084
Jun 18 13:32:03: %C4K_HWACLMAN-4-WARNINGSTRING: Entry: 48 PacketCount: 136
Jun 18 13:32:03: %C4K_HWACLMAN-4-WARNINGSTRING: Entry: 49 PacketCount: 24
Jun 18 13:32:03: %C4K_HWACLMAN-4-WARNINGSTRING: Entry: 80 PacketCount: 40196712
Jun 18 13:32:03: %C4K_HWACLMAN-4-WARNINGSTRING: Entry: 130 PacketCount: 44383869
Jun 18 13:32:03: %C4K_HWACLMAN-4-WARNINGSTRING: Entry: 16368 PacketCount: 1899438154
Jun 18 13:32:03: %C4K_HWACLMAN-4-WARNINGSTRING: Entry: 16384 PacketCount: 8531106
Jun 18 13:32:03: %C4K_HWACLMAN-4-WARNINGSTRING: Entry: 16416 PacketCount: 33274571
Jun 18 13:32:03: %C4K_HWACLMAN-4-WARNINGSTRING: Entry: 16432 PacketCount: 32117292
Jun 18 13:32:03: %C4K_HWACLMAN-4-WARNINGSTRING: Entry: 32752 PacketCount: 1899444422
As you can see from the timestamp, I'm getting these quite frequently. I don't have any outbound acl's applied anywhere so I;m confused about the warning message.
Thanks in advance,
--Brandon
I found this:
2. %C4K_PKTPROCESSING-4-ERRORPACKET: [char]
This message indicates that the software is unable to process a packet so the packet has been forwarded to the CPU instead. Because this event is unexpected, the packet is then dropped. This error indicates that the packet cannot be handled by the TCAM hardware, so the most likely cause is a hardware failure in the supervisor engine.
Recommended Action: Replace the supervisor engine.
15 Replies 15
Mohamad Qayoom
Level 3
Level 3
What IOS version are you running?
Mohamad
12.2(20)EWA3
Did you recently install the SUP V?
No -- this particular switch has been running with it's current configuration for quite some time.
The supervisor engine might have failed. I would open a Cisco TAC case and see if they want to replace the supervisor.
If the supervisor failed, would I still be able to pass traffic through it? This particular switch handles a lot of multicast traffic and I haven't seen any problems with the multicast traffic, just the errors in the log.
I found this:
as a mater of interest, was the CPU hitting the roof during this error ?
TIA
Sam
Not as far as I can tell... the 5/1/5 minute CPU stats were all low. I've attached the output to 'show proc cpu history'
Sorry -- here's the attachment
Don't reboot the card or you'll loose it.
Whoa! Can you elaborate on that? Did you experience a similar issue, with disastrous results?
Leo Laohoo
My apologies, Brandon. What I meant was with this error message, RMA is the way to go. But you might ask, if the sup card has failed, how come it's still operational. It will fail until you reload the supervisor engine.
Hope this helps.
Thanks for the clarification. I was worried that it might not even survive to the weekend. I've already got a new card on the way.
