Help with ISR4331 evaluation license
frankjmurray3
I am SO sick of Cisco and their F**king license bulls**t!
I've got an ISR4331 and I'm trying to activate the throughput eval license that came with it.
The Cisco documentation says:  use the license boot level command
okay....I give..... what is the syntax of the license boot level command? Because nothing seems to work.  I tried what I thought was the obvious: license boot level ipbase.  That's not a valid command. The question mark is no help.
Am I the only one who remembers the good old days when you could buy a Cisco router, configure it and it frickin worked!
16 Replies 16
Is the license right-to-use command, it can be seen with ? - cause I am trying to initiate this and when i issue ? I can only see license boot module .....
Does the above mean that you already have and purchased the appxk9 license, but you just haven't activated it yet?
