Help with network setup/VLAN
rodito
Visitor
Hi All,
Our new network is going to be like this after implementation.
Internet (Public IP /24) .1 <-> .2 ASA <-switch-Internal
   |----<-switch-DMZ
   |----<-switch-TechDepartment
ASA 5516-x
All switches are Catalyst 2960's
All of these switches are on their own interface ports on the ASA
Currently:
Internal - 10.1.1.1/24
DMZ - 172.16.1.1/24
TechDept - 172.21.0.1/24
My question is that we have the following other networks
- Wifi Network (10.1.2.1/24) and Management network (10.1.3.1/24) on the Internal network
- 172.21.1.1/24, 172.21.2.1/24, 192.168.11.1/24 on the TechDept network
- Would assigning VLAN within the respective switches be sufficient enough to do the routing?
- Should I do the routing on the switches for this networks?
--- Like set the switch IP to .1 and the ASA interface to .252 and then add route 0.0.0.0 0.0.0.0 ASA_IP 1 to the config for all the swiches?
say for switch-internal
vlan 1 - 10.1.1.1/24
vlan 10 - 10.1.2.1/24
vlan 20 - 10.1.3.1/24
For TechDept
vlan 30 - 172.21.0.1/24
vlan 40 - 172.21.1.1/24
vlan 50 - 172.21.2.1/24
vlan 60 - 192.168.11.1/24
How can I make sure I can ping or access these vlans from the other interface/switches/vlans?
Jeff
PacketSpartan
Level 4
Level 4
Hi Jeff
Each of the subnets will need their own VLAN on the ASA and then set up policies between them to allow access based on your security needs.
You can achieve it by having sub interfaces on the ASA for each of the vlan and trunk your switches to it.
CCNA R&S
Thanks TTboy1988
So something like this:
http://www.cisco.com/c/en/us/td/docs/security/asa/asa72/configuration/guide/conf_gd/intrface.html#wp1044006
What if I just want it very simple without seperating the networks? Would just defining the network in the ASA and then having the default route/gateway to 172.21.0.1 for all networks inside TechDept works? They are trying to migrate it one vlan anyways.
