Help with object groups and ACL
Andy White
Level 7
Level 7
I'm trying to use object groups as I can see this access list is going to grow so it will be easier to add to the groups, but I can't add the acl.  I've create the network and service groups.
access-list 123 permit tcp host 10.10.1.66 eq 601 10.15.10.0 0.0.0.255
object-group network servers1
host 216.58.233.70
host 212.84.71.166
object-group service servers1_Ports
tcp eq www
tcp eq 443
ip access-list extended 123
131 permit tcp object-group servers1 object-group servers1_Ports 10.15.10.0 0.0.0.255
Error
                                                             ^ 0.0.0.255
What am I doing wrong?
blau grana
Level 11
Level 11
Hello Andy,
Try to first specify service object-group, than network object-group ->
131 permit tcp object-group servers1_Ports object-group servers1 10.15.10.0 0.0.0.255
(config-ext-nacl)#permit ?
  object-group  Service object group
(config-ext-nacl)#permit object-group TEST ?
  object-group  Source network object group
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
It seems to want the network group first:
#131 permit tcp object-group ?
  WORD  Source network object group name
Ah I see:
131 permit ?
I see where is problem.
This is your original configuration.
But if you specify protocol "131 permit tcp" you can not use service object-group. So valid configuration will be like this:
131 permit object-group servers1_Ports object-group servers1 10.15.10.0 0.0.0.255
- without TCP and service object-group first
OR
131 permit tcp object-group servers1 eq 80 443 10.15.10.0 0.0.0.255
- with TCP, without service object-group and with ports explicitely configured
Best Regards
