help with packet tracer 2.1.1.5
hello everyone I am new to packet tracer and am having trouble getting the pc to ping cisco.com can someone pls healp me find out what's wrong because I even tried redoing the whole network from scratch
thanks
Martin L
you are almost there...
PC pings server OK using IP address, lust takes a few seconds for ARP to resolved.
PC web browser is OK if you type in IP of server , aka http://208.67.220.220
But if I type in  cisco.com in PC web browser, I get "Host Name Unresolved" error.  So, DNS resolution fails here.
I think I found typo: DNS setting on Router should be 208.67.220.220 , not 220.67.220.220
Regards, ML
**Please Rate All Helpful Responses **
8 Replies 8
Martin L
Regards, ML
Yes, definitely a typo: DNS setting on Router should be 208.67.220.220 , not 220.67.220.220.
fix that and refresh IP of PC to get it working.
Regards, ML
Thank you! Could you instruct me on how you reached that conclusion?
I noticed difference in IPs after looking at PC settings. No magic here, just look carefully at settings to verify all
Also that did not solve the problem, even when i used the 208 DNS address APIPA is still used
odd. I can ping cisco.com with the changed DNS server address (working file attached).
C:\>ping cisco.com
Pinging 208.67.220.220 with 32 bytes of data:
Reply from 208.67.220.220: bytes=32 time=65ms TTL=127
Reply from 208.67.220.220: bytes=32 time=76ms TTL=127
Reply from 208.67.220.220: bytes=32 time=55ms TTL=127
Reply from 208.67.220.220: bytes=32 time=78ms TTL=127
Ping statistics for 208.67.220.220:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 55ms, Maximum = 78ms, Average = 68ms
Double check all settings;  After fixing DNS setting, go to PC and refresh its IP address (ipconfig /renew) Or save PT file, close and re-open it.
Regards, ML
thank you everyone for the help
