Help with replacing a failed 3560G switch with identical appliance
mezzanine237
What do I need to know about replacing a failed 3560G switch with an identical switch? I have a grasp on how to replace a 3750g considering how easy it is with the 3750 being stacked, but I really don't know where to start in terms of replacing a 3560.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
As the other posters have noted, if you have a current backup of the prior 3560's config, you would just insure a current config is erased, and then load the backup config.
As Paul noted, you need to be careful if using VTP.  If using client or server modes, before adding configured device to your network, set VTP to transparent and then set it to to prior client or server mode after adding it to your network.
PS:
If you don't have a backup config, you'll need to reconfigure everything by hand
Hi Charles.
If you have a good backup of switch config,
Just copy it in flash and reboot the switch.
This should be enough.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hello
What role is the switch acting as - Vtp server/stp root?
If this is a vtp server then you need to transfer its role over to another switch then before its attached to the network - Apply its VTP configuration also MINUS its vtp mode , have this set to transparent and when the new switch has been attached to the network change its mode over to as it was as per old switch
Stp root-Again transfer its role over to another switch which is running as a secondary root, if you don't have a secondary root switch create on before you remove the okl switch.
Apply the old config with a higher priority as the secondary and when it attached and you happy with it attachment then promote back to stp root
If the old switch has failed whilst in production then I assume all above would have been set anyway as per redundancy sla then neither of the above is applicable and you should be okay -but I still would have the vtp mode of the new switch set to transparent in any scenario when attaching a new switch to an existing LAN
Res
Paul
Kind Regards
Paul
Joseph W. Doherty
Disclaimer
Posting
PS:
mezzanine237
Thanks for your responses.
