Help with setting up 2 x 5520 Firewall & 2 x 2960G Switches
derek.bannard
I'm looking to do the following... but am lost with all the options and variable.
Hopefully one of the guru's here can help with a sample config I can expand upon.
P.S.  I'm new to Cisco IOS so please be gentle.
I have two firewalls set to active/standby using the management port for failover communication.  Works great.
I have two switches that I need to do something similar, but am unsure how to do it.
Can you please provide a configuration that would work for what I am looking for in the diagram above?
Thank you very much in advance!
derek.bannard wrote:
Sorry, guess I should have clarified.
I have the firewalls setup so they failover and the vlnas are seperated on them.  I however do not have any configuration on the switches... and thus my dilema.  I don't know how to setup the switches.
Ahh okay.
As an example - vlan 10 = outside, vlan 11 = DMZ, vlan 12 = inside
The 2 switches will interconnect via an etherchannel trunk
2960 switch
create vlans on switch -
vtp mode transparent
vlan 10
name outside
vlan 11
name dmz
vlan 12
name inside
create L2 etherchannel trunk -
int po1 <-- this interface will be automatically created when you configure gi0/1 and gi0/2
switchport mode trunk
switchport trunk allowed vlan 10,11,12
int gi0/1
channel-group 1 mode on
int gi0/2
then choose ports for the outside/dmz/inside vlans
int gi0/4
switchport mode access
switchport access vlan 10
int gi0/5
switchport access vlan 11
etc..
Edit - you would still want to set a hostname and secure access to the switches. Attached is a link to the config guide for the 2960 switch -
2960 configuration guide
Jon
7 Replies 7
Ganesh Hariharan
Clarify few things how is the traffic flow is between the zones and towards outside world, from the diagram what i feel all the traffic are routed via firewall only as 2960G series are purely a L2 switches and is there any defaultgateway command configured in 2960g switches.
Ganesh.H
The traffic flow is as follows:
Source:  Internet
Into Outside VLAN (SW), then route to Firewall Outside VLAN, then based on IP, to DMZ or Internal VLAN's.
Source:  Internal
Based on IP routes to internal machines, DMZ or Outside for Internet access.
Source:  DMZ
Jon Marshall
Derek
Not sure what you are looking for. If the diagram is a representation of what you have then you are fine already because your 2 switches are interconnected via a trunk link which i assume is allowing the outside/dmz/inside vlans across. The vlans are being routed through the 5520 firewalls which is as it should be.
Is there something specific you need help on ?
Jon
I have the firewalls setup so they failover and the vlans are seperated on them, nothing past that point.  I however do not have any configuration on the switches... and thus my dilema.  I don't know how to setup the switches.
Ahh okay.
2960 switch
vlan 10
name outside
vlan 11
name dmz
vlan 12
name inside
int gi0/1
int gi0/2
int gi0/4
int gi0/5
etc..
Jon
Jon's explantion about configuring l2 switches is sufficient for your setup as your firewall is doing the routing stuff which is already configured in Active/Standby fashion,so better configure vlans in your switches and allow them over the trunk as suggested by Jon.
Ganesh.H
derek.bannard
Thank you to both of you!
You guys rock!
