Help with Switch Configuration
sandman77777
Hello All,
I am new to Cisco Networking and trying to setup a network. Here is how I want to setup.
Internet -> Cisco ASA -> Cisco Switch.
Very basic.  I tried configuring the ASA and Switch but I am stuck and don't know what I am doing wrong.  I can't ping from the switch to the ASA.  So I added the PC to the network so I can test.
Internet -> [Port E0/0] Cisco ASA [Port E0/1] -> [Port G1/0/24] Cisco Switch
                                    Cisco ASA [Port E0/2] -> PC
Now from the PC I can ping the ASA (ip address 10.10.10.73) but when I try to ping 10.10.10.73 from the switch it does not work.
Please see attached files for configurations.
Thanks for your help.
Please correct your interface Ge1/0/24 configuration on the switch, it is configured in trunk with native vlan 1, and ASA E0/1 belongs to vlan 50, so the switch would send the frames tagged to the ASA and it would not be able to interpret them, you would do one of the two solutions:
interface GigabitEthernet1/0/24
 switchport mode access
 switchport access vlan 50
And remove any remaining trunk configuration on that port.
or
Configure the native vlan on that trunk port as vlan 50 so the switch would send the frames untagged to ASA:
 switchport trunk native vlan 50
I would advice to use the first solution, which would be more accurate. Also please note that the ASA and the switch vlan 50 interface has different subnet mask, it would not be the cause of the issue you are having, but you should adjust them anyway.
Aref
or
Aref
sandman77777
You are awesome.  That works!
Thank you very much for your help.
Amit
:) glad to know that. You are very welcome Sandman.
Aref
