Help with this %ILET-1-AUTHENTICATION_FAIL: This Switch may not have been manufactured by Cisco or with Cisco's authorization
Hello Community :
Since I upgrade my Cisco Switch Catalyst 2960X this message is coming out every minute. Do you have any Idea how Can I solve this issue?
Feb 27 13:55:13.975: %ILET-1-AUTHENTICATION_FAIL: This Switch may not have been
manufactured by Cisco or with Cisco's authorization. This product may contain software that was copied in violation of Cisco's license terms. If your use of t
his product is the cause of a support issue, Cisco may deny operation of the pro
duct, support under your warranty or under a Cisco technical support program suc
h as Smartnet. Please contact Cisco's Technical Assistance Center for more info
rmation.
Jaderson Pessoa
Hello @GiancarloRamirez2030 ,
There is a good topic here talking about your issue: https://community.cisco.com/t5/switching/default-ios-shipped-on-switch-ilet-1-authentication-fail/td-p/1848527
They suggest that is necessary upgrade IOS, in case you still having the issue, contact Cisco Sales/Partner.
Best Regards.
Jaderson Pessoa
*** Rate All Helpful Responses ***
