Help with understanding route-maps
Shawnw4401
Could someone explain to me what are route-maps and how they work? I am trying to understand it a little in my lab, but I don't think I am grasping it too well.
Here's my scenario:
I have two groups: LAN and Wi-Fi. The IPs associated with each group is only allowed to communicate within those IP. So no LAN device should be able to communicate with Wi-Fi, with the exception of 10.71.0.16/28. Below is the IPs associated with the two groups.
LAN IP Addresses Wi-Fi IP Address
10.1.0.0/30
10.1.0.4/30
10.25.0.0/28
10.71.0.16/28
10.2.0.0/30
10.2.0.4/30
10.49.0.32/28
And I had something like this:
ip access-list standard LAN_2
permit 10.1.0.4 log
deny any log
ip access-list extended FW_IN
deny ip any any log
ip access-list extended LAN_11
permit ospf 10.1.0.4 0.0.0.3 any log
deny ip any any log
ip access-list extended LAN_12
permit icmp 10.25.0.0 0.0.0.15 any log
deny icmp any any log
deny ip any any log
ip access-list extended LAN_13
permit icmp 10.71.0.0 0.0.0.15 any log
deny ip any any log
ip access-list extended LAN_14
permit icmp 10.1.0.0 0.0.0.3 any log
deny ip any any log
ip access-list extended LAN_15
permit icmp 10.1.0.4 0.0.0.3 any log
deny ip any any log
ip access-list extended LAN_16
permit tcp 10.25.0.0 0.0.0.15 any gt 1 log
permit udp 10.25.0.0 0.0.0.15 any gt 1 log
deny ip any any log
ip access-list extended LAN_17
permit tcp 10.71.0.16 0.0.0.15 any gt 1 log
permit udp 10.71.0.16 0.0.0.15 any gt 1 log
deny ip any any log
route-map LAN permit 5
match ip address LAN_1
set ip next-hop 10.1.0.1
route-map LAN permit 10
match ip address LAN_2
set ip next-hop 10.1.0.5
route-map LAN permit 55
match ip address LAN_11
route-map LAN permit 60
match ip address LAN_12
route-map LAN permit 65
match ip address LAN_13
route-map LAN permit 70
match ip address LAN_14
route-map LAN permit 75
match ip address LAN_15
route-map LAN permit 80
match ip address LAN_16
set vrf Computers
set vrf Computers next-hop 10.25.0.2
set ip global next-hop 10.1.0.5 10.1.0.6
set default interface GigabitEthernet0/0.1025
route-map LAN permit 85
match ip address LAN_17
set vrf Servers next-hop 10.71.0.18
set default interface GigabitEthernet0/0.1071
But, of course, that didn't work. I was receiving no packets through route-maps as shown:
Ext_Router#show route-map LAN
route-map LAN, permit, sequence 5
Match clauses:
ip address (access-lists): LAN_1
Set clauses:
Policy routing matches: 0 packets, 0 bytes
route-map LAN, permit, sequence 10
Match clauses:
ip address (access-lists): LAN_2
Set clauses:
route-map LAN, permit, sequence 55
Match clauses:
ip address (access-lists): LAN_11
Set clauses:
route-map LAN, permit, sequence 60
Match clauses:
ip address (access-lists): LAN_12
Set clauses:
route-map LAN, permit, sequence 65
Match clauses:
ip address (access-lists): LAN_13
Set clauses:
Now I think it is I am partially not understanding it correctly, and I am also misconfiguring it (I am almost sure of this one).
So, for my question:
1) What am I doing wrong?
2) What is the point of different sequence and should I use different sequences in my scenario?
3) What are some tips or pointers to look for when using route-maps?
All input is greatly appreciated. Thank you.
first of all, what, that is, which interface(s), are these route maps applied to ? The route maps by themselves do not do anything unless you apply them somewhere.
Are both your LAN and WiFi networks on the same router ? Post the entire config of your lab if possible...
Georg,
The route-map was applied to two interfaces, both LAN interfaces (Gi0/0.1100 and Gi0/1.1100).
Here is the configuration of the router:
version 15.1
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname External_Router
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
clock timezone CST -6 0
dot11 syslog
no ip source-route
ip cef
ip domain name MyTestLab.com
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip inspect log drop-pkt
ip inspect name FW_OUT tcp router-traffic
ip inspect name FW_OUT udp router-traffic
ip inspect name FW_OUT icmp router-traffic
ip inspect name FW_OUT ftp
ip inspect name FW_OUT tftp
ip inspect name FW_OUT bootpc
ip inspect name FW_OUT bootps
ip inspect name FW_OUT bgp
ip inspect name FW_OUT dns
ip inspect name FW_OUT echo
ip inspect name FW_OUT ftps
ip inspect name FW_OUT http
ip inspect name FW_OUT https
ip inspect name FW_OUT ntp
ip inspect name FW_OUT ssh
no ipv6 cef
parameter-map type inspect global
log dropped-packets enable
voice-card 0
license udi pid CISCO3845-MB sn FOC105013BA
vtp domain MyTestLab.com
vtp mode transparent
vtp version 2
username stw privilege 15 secret 5 $1$QEsA$2RsNy20ARS1Sg68xDLDSQ0
redundancy
vlan 100
name Management_LAN
vlan 999
name Native_VLAN
ip ssh authentication-retries 2
ip ssh source-interface Loopback0
interface Loopback0
no ip address
interface Loopback1100
ip address 10.255.255.252 255.255.255.255
ip ospf network point-to-point
interface Loopback1200
ip address 10.255.255.253 255.255.255.255
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/0.1100
description To LAN Router
encapsulation dot1Q 1100
ip address 10.1.0.5 255.255.255.252
ip flow ingress
ip flow egress
ip policy route-map LAN
interface GigabitEthernet0/0.1200
description To Wi-Fi Router
encapsulation dot1Q 1200
ip address 10.2.0.5 255.255.255.252
ip flow ingress
ip flow egress
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1.100
encapsulation dot1Q 100
ip address 192.168.100.3 255.255.255.0
ip access-group FW_IN in
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip inspect FW_OUT out
interface GigabitEthernet0/1.1100
description To LAN Firewall
ip address 10.1.0.2 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
interface GigabitEthernet0/1.1200
description To Wi-Fi Firewall
ip address 10.2.0.2 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip policy route-map Wi-Fi
interface FastEthernet0/0/0
no ip address
shutdown
interface FastEthernet0/0/1
no ip address
shutdown
interface FastEthernet0/0/2
no ip address
shutdown
interface FastEthernet0/0/3
no ip address
shutdown
interface Vlan1
no ip address
shutdown
router ospf 1100
router-id 10.255.255.252
network 10.1.0.0 0.0.0.3 area 0
network 10.1.0.4 0.0.0.3 area 0
network 10.255.255.252 0.0.0.0 area 0
default-information originate
router ospf 1200
router-id 10.255.255.253
network 10.2.0.0 0.0.0.3 area 0
network 10.2.0.4 0.0.0.3 area 0
network 10.255.255.253 0.0.0.0 area 0
ip forward-protocol nd
no ip http server
no ip http secure-server
permit 10.1.0.4 log
deny any log
deny ip any any log
deny ip any any log
deny ip any any log
deny ip any any log
deny ip any any log
deny ip any any log
deny ip any any log
deny ip any any log
set vrf Computers
control-plane
mgcp profile default
banner login ^C
W A R N I N G
THIS IS A PRIVATE COMPUTER SYSTEM.
This computer system including all related equipment, network devices
(specifically including Internet access), are provided only for
authorized used.
All computer systems may be monitored for all lawful purposes, including
to ensure that their use is authorized, for management of the system, to
facilitate protection against unauthorized access, and to verify security
procedures, survivability and operational security.
Monitoring includes active attacks by authorized personnel and their
entities to test or verify the security of the system. During monitoring,
information may be examined, recorded, copied and used for authorized
purposes.
All information including personal information, placed on or sent over
this system may be monitored. Uses of this system, authorized or
unauthorized, constitutes consent to monitoring of this system.
Unauthorized use may subject you to criminal prosecution. Evidence of
any such unauthorized use collected during monitoring may be used for
administrative, criminal or other adverse action. Use of this system
constitutes consent to monitoring for these purposes.
^C
line con 0
exec-timeout 0 0
logging synchronous
login local
line aux 0
line vty 0 4
logging synchronous
login local
transport input ssh
transport output ssh
line vty 5 15
logging synchronous
login
transport input all
scheduler allocate 20000 1000
