Help with VLAN setup
tanoopsungha
Community Member
Hi Everyone,
I need help setting up a VLAN. We just bought the SG500x switches and we need to create several VLANs.
So for example:
192.168.1.x --> Vlan 1
192.168.2.x --> Vlan 2
192.168.3.x --> Vlan 3
What I would like to know is how do I come about setting this up and do I have to do something with my DHCP server to allow this to happen?
Sandeep Choudhary
Hi Tanoop,
To create a VLAN:
STEP 1
Click VLAN Management > Create VLAN. The Create VLAN  page is displayed.
The Create VLAN page displays the following fields for all VLANs:
VLAN ID
—User-defined VLAN ID.
VLAN Name
—User-defined VLAN name.
Type
—VLAN type:
Dynamic
—VLAN was dynamically created through Generic VLAN
Registration Protocol (GVRP).
Static
—VLAN is user-defined.
Default
—VLAN is the default VLAN.
STEP 2
Click Add to add a new VLAN or select an existing VLAN and click Edit  to modify the VLAN parameters. The  Add/Edit VLAN  page is displayed.  The page enables the creation of either a single VLAN or a range of VLANs.
STEP 3
To create a single VLAN, select the VLAN radio button, enter the VLAN ID (VID) and optionally the VLAN Name. To create a range of VLANs, select the  Range  radio button, and specify the range of VLANs to be created by entering the Starting VID and Ending VID, inclusive. When using the Range function, the maximum number of VLANs you can create at one time is 100.
STEP 4
Click Apply
Use this admin ghuide to creat vlan and configure vlan interface settings:
www.cisco.com/en/US/docs/switches/lan/csbms/Sx500/administration_guide/500_Series_Admin_Guide.pdf
Please rate if it helps.
want to know more  about, how to create the VLAN(s).
