Help with VLAN VRF setup
perpaal
I`m setting up VRF on some VLANs, to isolate them.
I have set this up on my 3560:
C3560G(config)#ip vrf v10
C3560G(config-vrf)#rd 500:1
C3560G(config-vrf)#route-target export 500:1
C3560G(config-vrf)#route-target import 500:1
C3560G(config-vrf)#exit
C3560G(config)#interface vlan 10
C3560G(config-if)#ip vrf forwarding v10
% Interface vlan10 IP address 10.1.0.1 removed due to enabling VRF v10
C3560G(config-if)#ip address 10.1.0.1 255.255.255.0
C3560G(config-if)#interface vlan 11
% Interface vlan11 IP address 10.1.1.1 removed due to enabling VRF v10
C3560G(config-if)#ip address 10.1.1.1 255.255.255.0
C3560G(config-if)#interface vlan 12
% Interface vlan12 IP address 10.1.2.1 removed due to enabling VRF v10
C3560G(config-if)#ip address 10.1.2.1 255.255.255.0
C3560G(config-if)#interface vlan 13
% Interface vlan13 IP address 10.1.3.1 removed due to enabling VRF v10
C3560G(config-if)#ip address 10.1.3.1 255.255.255.0
but this does not seem to work.
When connecting equipment to these VLANs, they can not communicate with each other.
I have only set up VRF on the 3560, as this is used as router, and is the only switch supporting VRF in the network.
Do I have to configure VRF on all switches using this VLANs, or what am I doing wrong here?
perpaal
Sorry, had some ACLs I had not removed.
All works now as expected
