hi Wrongprotocol on CATOS on LACP
cssam
I have problem in CATOs switch that is -
(enable) show port channel 1
Wrong protocol type. Module 1 is set to LACP
Sup1A we are using
krahmani323
Level 3
Level 3
Hello Cssam,
I suppose you have « set channelprotocol lacp [1] » configured on the CatOS. It indicates the unique bundling protocol used for the whole module.
Indeed in CatOS all ports in an EtherChannel must use the same protocol; you cannot run two protocols on one module http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/8.x/configuration/guide/channel.html#wp1039836
This is the reason why you cannot issue the command to validate the the pagp information.
In order to check the Channel-protocol information issue the ‘show port lacp-channel’ instead as LACP is used here.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/8.x/command/reference/sh_p_sn.html#wp1428547
If you want (depending of your current etherchannl config) to configure a PagP etherchannel, you will have to redifine the channel protocol (global or on a module basis) => set channelprotocol pagp  [1]
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/7.x/command/reference/ses_sete.html#wp1084706
Thus you would be able to see the show port channel 1 output (of course, be careful of what etherchannel already configured)
Hope that helps.
Kind regards.
Karim
hi karim,
we have configuration as below -
#channelprotocol
set channelprotocol lacp 1
set channelprotocol lacp 2
#port channel
set port lacp-channel 1/1,2/1 11
but there is no multiple channel protocol running
Thank you for the config.
So you have configured LACP for modules 1 & 2.
So, in order to see the details of your Etherchannel you can use show port lacp-channel
About your comment "but there is no multiple channel protocol running" => That is normal as you cannot run two protocols (PagP and LACP at the same time) on one module.
Hope that helps.
Kind regards.
Karim
amikat
Your command defaults to PAgP. You can either use the command "show port channel all" which should give you the information about both PAgP and LACP channels or you have the option to use the command "show lacp-channel" instead.
Best regards,
Antonin
